It also depends on the leathers you're marking, veg tan or chrome.
I know it would need testing to get a feel for it, but I've seen some will heat it over an alcohol lamp or such before pressing it into chrome tan leather. Veg tan, can case the leather first to make it more  easily impressionable.
The only material I plan (at this stage) to be using is Veg tan.  My primary focus is knife sheaths for my custom knives.
Chris
"All things are difficult before they are easy."
                                          (Fortune Cookie Proverb)
18 hours ago, Alaisiagae said:
 Which Tandy press, the red one or the grey one?
The grey one; https://tandyleather.world/products/craftool-pro-hand-press?_pos=3&_sid=2f2862f43&_ss=r
I preferred the grey one as I bought the adaptors for the 3D/2D stamps for it  https://tandyleather.world/products/press-dies-for-hand-press?pr_prod_strat=copurchase&pr_rec_pid=4602824392839&pr_ref_pid=4602666549383&pr_seq=uniform
 I have a half ton arbor press, but I can't get it to do deep impressions, no matter how hard I push the lever.
Not many people do this; ~~ its not just about pressing the stamp, the leather needs to be cased just about right, and leave the pressure on for about 20 seconds or more
On 10/7/2020 at 2:06 PM, Chris623 said:
 I'd love to have that Tandy press, but can't afford it.  If I could afford that, I could buy several of the Arbor Presses that are on the used market in my area.
Would you believe that no place in my country had an arbor press of any size. Only one was willing to import one. It was large and was 12T pressure and was going to cost around £600. Tandy had theirs on sale so I got it for about £180
18 hours ago, Chris623 said:
In talking with some leather workers, they are saying a typical maker's mark would need at least a 1 1/2 Ton arbor press.   I don't know anything about Tandy's presses.
Nonsense. The Tandy is 1.25 T and if I don't carefully adjust its depth to press I can, and have, punched a stamp right through 3mm thick l leather. Just the other night I tested a self-made resin stamp on 2mm leather. I didn't use the press nor a hammer, I just pressed it down hard on the cased leather and held it there for about 20 seconds. I got a very decent test stamping, not great but passable
I had no idea the Gray Tandy press had that much compression power.  Still, it's about 7 times what I can afford right now.  I've decided to just use my 20 Ton hydraulic press.  I'll need to "accurize" it some so the beam that travels up and down doesn't have any slop.  Other than that, I think it will do quite nicely.
I do find your comment about having to "hold it there for about 20 seconds" interesting.  When we use a stamp on leather............any of the hand-held impression stamps...........it is only pressed into the leather the amount of time the hammer is hitting it.  Why would a maker's mark have to be held under pressure for 20 seconds?
Chris
All stamping should take time.
When you use a bar and hammer, walk the the stamp. 1st hit, centre to locate it, then tip to top left, hit again, tip to top right, hit, tip to bottom right, hit. tip to bottom left, hit. Finish with another centred hit. All this takes more than 20 seconds. The time is needed for the leather fibres to become fully compressed and retain that compression. If you just press down briefly and release the fibres can reshape themselves a bit after release of the pressure on them
Try it this way and you'll find you get sharper more permanent impressions
I use the "four points of the compass" method, much as you recommend.  Just didn't think of it as the same as 20 seconds under constant pressure.
Chris
1 ton arbor press works for me.  Also a dead blow hammer works.  A regular mallet type hammer often bounces so you can get a ghost image due to the bounce.  Dead blow hammer eliminates that.
Tom
Thanks, Tom.  I had already figured on using a dead-blow hammer if hand holding the die.  Just placed and order for my maker's mark.  Their website mentioned they are about 3 weeks behind due to the Pandemic, so I guess I'll have to be patient.
Chris
