Members Danne Posted November 12, 2020 Members Report Posted November 12, 2020 (edited) Maybe start with something simple like a card case? Everything I do is fully lined and my templates would be hard to explain to someone else. But a while ago I made a simple card case template for someone. Use leather around 1-1.2mm To avoid seeing the top pocket through the bottom pocket, it can be good to skive the edges. It doesn't have to be perfect since it won't be visible. A safety beveler will work fine if you don't feel comfortable using a skiving knife. (This is A4, i'm not sure if it's possible to print in letter size, if not just tell me, and I make one in letter size. Edit: I didn't really explain the distance piece. Glue it to some thicker card paper, and you can use it to align the distance for the top pocket from the edge. Scribe a line where you need to roughen your leather grain for glue, and also use it when you assemble your pocket so it's the correct distance from the top. 2card.pdf2card_template.pdf Edited November 12, 2020 by Danne Quote
