Members EMI Posted November 3, 2020 Members Report Posted November 3, 2020 This is my first post after a couple of years delving into the threads of this forum. First and foremost, I would like to express my gratitude and appreciation to this community for the great wealth of knowledge and expertise so generously shared for the benefit of everyone and especially members in need of assistance. I am located in Athens area, Greece and have recently bought a wide (6mm) zig-zag version of the PFAFF 138-6 in very good condition, complete with table and clutch motor, missing only the presser foot knee lifter assembly (my search for replacement parts proved so far unsuccessful). The full class designation details of the machine are 138-6/21 915/02-BS, meaning as per PFAFF coding system that she was configured from the factory for medium weight (B) fabric (S) and with part sets for cording & tween seams (915/2). As such she is fitted with an adjustable tween needle holder, part no. 91-064 652-91 (see attached dwg from parts manual and holder’s close-up photos for better illustration purposes). According to PFAFF’s manual (as explained also in another relevant thread of this forum) she is supposed to be used with 438KK system needles of sizes from 60 to 100 for the “B” type. SCHMETZ catalog indicates 265KK and DPx438KK as 438KK equivalent and differentiate them from the regular 265 and 438 as having shorter shank. Much of my confusion stems from the following contradictory facts: 1. The machine came with a rather faded sticker on her face cover plate indicating what appears to be 134RK system needle (see photo). . The machine came with an assortment of PFAFF system 134 needles of various sizes from 120 to 180 (see photo). Is PFAFF system 134RK the same as regular 134 ? Are 438KK and 134 needles interchangeable? They appear to have the same length of 33.9mm to the needle eye and same 2mm shank diameter. I am not sure about the role of the shank length though. 3. After thorough cleaning, oiling and adjustment of straight stich (“0” zig-zag width) position the machine appears to be sewing happily in all modes (straight & zig-zag) and full stitch range ( stitch lengths & zig-zag width) with the existing 134 needles and V69 thread. Apparently, needle bar length/hook timing has been adjusted for the dimensions of the 134 system needles. However, it appears that the needle is partly grabbed in holder’s center slot between the two L&R adjustable blocks rather than fully inserted in the split hole provided for this purpose (the resulting hole with the L&R blocks matting surfaces in contact is to small for the 2mm needles shank). This kind of needle mounting doesn’t look right from an engineering point of view and frankly speaking I don’t feel very comfortable operating the machine this way. 4. Since both 438KK and 134 system needles have a 2mm shank diameter, incompatible (oversized ?) with the existing smaller mounting holes of the needle holder, what needle system could be more suitable for use in a single (center line) or tween needle (L & R holes) configuration in this holder? Since its the first time I am dealing with a single bobbin- double needle configured machine I have no clue on how to proceed. My intentions are to use her for medium weight fabric and canvas/upholstery work , supplementary to my other two sewing machines (a compound feed Consew 226R and a cylinder arm Adler 69 ) . Any comment/advise on the above will be highly appreciated. Thanks in advance for any possible response. Quote
Members Constabulary Posted November 3, 2020 Members Report Posted November 3, 2020 (edited) I´m not 100% sure but the double needle holder where meant for small diameter shanks like the 287 / 1738 needle if I recall that correctly. Edited November 3, 2020 by Constabulary Quote
Members EMI Posted November 3, 2020 Author Members Report Posted November 3, 2020 1 hour ago, Constabulary said: I´m not 100% sure but the double needle holder where meant for small diameter shanks like the 287 / 1738 needle if I recall that correctly. Thanks for the swift response. I am trying to find a way to measure the internal diameter of the holder's holes so I could search for appropriate needles by their diemsions ( shank diameter/length). It appears though that the center hole diameter D1 is larger than the side ones D2. Quote
Members EMI Posted November 4, 2020 Author Members Report Posted November 4, 2020 13 hours ago, Constabulary said: I´m not 100% sure but the double needle holder where meant for small diameter shanks like the 287 / 1738 needle if I recall that correctly. Following the above suggestion I found in another thread here ( link below) that the 1738 system has been also proposed as a potentially successful alternative to the 130B for the PFAFF adjustable needle holder. https://leatherworker.net/forum/topic/76473-pfaff-138-help/ On 7/4/2017 at 8:48 AM, alexitbe said: An alternative to Needle System 130B is the 1738 needle system. It has been used to some success on Pfaff 130-14-15 sewing machine, which is also requires the round schank 130b for its adjustable needle holder. The 1738 is aka DBX1 16X231 16X257 1738. Cheers Alex So I've ordered some 1738/287/ DBx1 needles to give it a try and see. Their 1.62mm shank might fit properly in the holder's mounting holes. I will revert with the results in due time. Quote
Members Constabulary Posted November 4, 2020 Members Report Posted November 4, 2020 (edited) Are you sure D2 is the needle holder? The double needle afaik is for sewing tucks and for sewing tucks I think the two "D2 holes" are to far apart - or not? If D2 are needle holders would the needles pass through the slot in the needle plate? I´m not sure... I´d rather say the 2 needles are clamped in the notch left and right of the center needle holder but 1738 most likely is the right needle anyway. Edited November 4, 2020 by Constabulary Quote
Members nylonRigging Posted November 4, 2020 Members Report Posted November 4, 2020 - - 19 hours ago, EMI said: Since its the first time I am dealing with a single bobbin- double needle configured machine I have no clue on how to proceed. My intentions are to use her for medium weight fabric and canvas/upholstery work , supplementary to my other two sewing machines (a compound feed Consew 226R and a cylinder arm Adler 69 ) . Any comment/advise on the above will be highly appreciated. Might have your machine model have come with ( 2 ) factory needle clamp setups ? , single and a double . My Bernina 217 straight/zigzag combo machine as 2 thread tension assembly setup like your Pfaff model . and also the Bernina offered 2 different factory needle clamp setup's to quick change out for single/double needle stitching . ( I don't think ? ) that ( D 1 ) slot in the center of the Needle clamp is for a needle . space ( wide gap ) in between the 2 needle hole, It In No Way resembles a hole to place a machine needle into . That needle clamp in your Pic. looks like a double-needle clamp only . - Quote
Members EMI Posted November 4, 2020 Author Members Report Posted November 4, 2020 (edited) 3 hours ago, Constabulary said: Are you sure D2 is the needle holder? The double needle afaik is for sewing tucks and for sewing tucks I think the two "D2 holes" are to far apart - or not? If D2 are needle holders would the needles pass through the slot in the needle plate? I´m not sure... I´d rather say the 2 needles are clamped in the notch left and right of the center needle holder but 1738 most likely is the right needle anyway. Thanks Constabulary & NylonRigging for your follow up. I wish I knew !! However, I don't see the reason to be made by PFAFF with 4 channels (2 inner & 2 outer) if it was meant to be used only with the outside ones. Things are getting even more confusing from the fact that 3 out of the 4 needle holes are drilled all the way through to the top (with the corresponding needles vertical travel terminating at the holder's recess top flange) while the inner channel of the left block stops short from the top (see attached photos). And while the diameter of the outer holes is approx. 1.62mm the inner ones are approx.1.8mm. Edited November 4, 2020 by EMI photos removal Quote
Members EMI Posted November 4, 2020 Author Members Report Posted November 4, 2020 (edited) I’ve checked the manual of PFAFF 130-115 (predecessor of the 138) to find any possible info related to PFAFF’s twin needle holder configuration. As it turned out, the 138-6 twin needle holder seems to be a variation of the 130-115 one with essentially the same features. It is meant to be used as a single, double or triple needles holder with (most probably) 130B system needles. Extracted pages of 130-115 manual hereby attached for easy reference. It appears that round shank 130B needles are used in the outer holes. A single 130B needle or two 130B needles may be inserted in the middle clamp jaws grooves. For very fine cording two special type left and right needles 130BL and 130BR with flattened shank (like the domestic needles) are inserted in the middle clamp jaws grooves as a single needle with the flat surfaces facing each other. I still didn’t manage to find out the purpose of the L & R middle grooves length difference though. My biggest concern now is if the machine could be used with its current needle bar/holder and probably matching DPx1/1738/287 needles for my intended purposes (medium weight fabric & canvas/upholstery works with needles sizes up to 110/18-120/19) or shall I consider modifications to a regular 138-6 needle bar/holder ( assuming availability of necessary replacement parts). Edited November 4, 2020 by EMI Add extra photo, editorial corrections Quote
Members EMI Posted November 4, 2020 Author Members Report Posted November 4, 2020 After a more careful re-measurement of the needle holder holes I believe that my previous assessment is wrong, so please disregard my last post above. The two outer holes are 13.5mm apart (a rather big distance for a single bobbin twin needle configuration) and of 1,44mm diameter (too small for any needle shank), so I tend to believe that they are just clamp’s slit termination strain relief holes and not needle sockets. It appears to me that the only needle sockets are the two middle holes, approx. 1.85mm in diameter and of 7.93mm (L) and 8.72mm(R) length. Quote
Members EMI Posted November 4, 2020 Author Members Report Posted November 4, 2020 11 hours ago, Constabulary said: Are you sure D2 is the needle holder? The double needle afaik is for sewing tucks and for sewing tucks I think the two "D2 holes" are to far apart - or not? If D2 are needle holders would the needles pass through the slot in the needle plate? I´m not sure... I´d rather say the 2 needles are clamped in the notch left and right of the center needle holder but 1738 most likely is the right needle anyway. You were absolutely right. Quote
Members EMI Posted November 5, 2020 Author Members Report Posted November 5, 2020 On 11/4/2020 at 9:05 AM, EMI said: So I've ordered some 1738/287/ DBx1 needles to give it a try and see. Their 1.62mm shank might fit properly in the holder's mounting holes. I will revert with the results in due time Update on the saga of PFAFF's double needle holder needle system. I've tried a few Groz Beckert DBx1/1738/16x257/287WH and DLx1 (same basic dimensions but with shorter shank) needles but none of them found possible to be clamped in the needle holder. It turned out that their shank diameter (measured at 1.55mm) is too small for the clamping range of this holder. Quote
Members EMI Posted November 8, 2020 Author Members Report Posted November 8, 2020 After my unsuccessful attempt to fit DBx1/1738/16x257/287WH needles I’ve tried once more the DBX5-134 needles. Their 2mm nominal diameter shank (actual measured diam. of Schmetz needle 1.94mm) is a very tight fit in holder’s holes, impossible to be inserted by hand and feasible only with a pair of pliers, but it worked. I centered the right needle for single needle sewing. Twin needles may be set up to 6mm apart (i.e. machine’s zig-zag width range). Upon fine tuning of hook timing tests in both single and twin needle modes were done with satisfactory results. Quote
Members EszterB Posted February 6, 2022 Members Report Posted February 6, 2022 Good morning All! I know it hasn't been much activity on this thread for a while, but I found it very detailed and interesting topic, especially since I am struggling with my Pfaff 38 and the very same dilemma... I love the pictures too! My 1928 Pfaff 38 came with a single regular domestic flat shank needle clamped in the middle slot. There wasn't any indication on the machine or in the drawer about the correct needles. I found a couple of manuals online in French and German. 130 needle system is recommended in the manual (can't remember seeing 130b, I'll have to double check it) when in double needle mode, the max needle space is 4.5mm on my machine. My trouble is, that the needle clamp screws are really worn, and although I found replacement screws that supposed to be the same the new ones doesn't fit. I was thinking about changing the whole needle clamp unit to a single one from a Pfaff 34... I was wondering if the double clamp from the 138 would fit my 38? The needle clamp screws on my machine go in diagonally and not straight, other than that looks pretty much the same. https://imgur.com/a/YzrfnnB Eszter Quote
Members DrmCa Posted February 6, 2022 Members Report Posted February 6, 2022 Would buying a thread gauge and caliper be an option? That way you could find out the thread pattern and look to obtain the correct screws from alternative channels. Quote
Members EMI Posted February 12, 2022 Author Members Report Posted February 12, 2022 On 2/6/2022 at 11:20 AM, EszterB said: Good morning All! I know it hasn't been much activity on this thread for a while, but I found it very detailed and interesting topic, especially since I am struggling with my Pfaff 38 and the very same dilemma... I love the pictures too! My 1928 Pfaff 38 came with a single regular domestic flat shank needle clamped in the middle slot. There wasn't any indication on the machine or in the drawer about the correct needles. I found a couple of manuals online in French and German. 130 needle system is recommended in the manual (can't remember seeing 130b, I'll have to double check it) when in double needle mode, the max needle space is 4.5mm on my machine. My trouble is, that the needle clamp screws are really worn, and although I found replacement screws that supposed to be the same the new ones doesn't fit. I was thinking about changing the whole needle clamp unit to a single one from a Pfaff 34... I was wondering if the double clamp from the 138 would fit my 38? The needle clamp screws on my machine go in diagonally and not straight, other than that looks pretty much the same. https://imgur.com/a/YzrfnnB Eszter It's a lovely machine and the twin needle holder gives you more configuration options than the single one. It doesn't worth the trouble to have it replaced for the sake of a couple worn screws ( especially since there is no guarantee that a second hand replacement part wouldn't have worn screws too). My advice is to measure with a caliper the external diameter and the length of your screws and get new matching ones. I've also replaced mine the same way. They were metric with M3 thread and tried different types (with hex socket and torx heads) Quote
Members EMI Posted February 12, 2022 Author Members Report Posted February 12, 2022 Details of the M3 types of screws I found compatible with my machine (I had to file a bit the heads as they were a bit larger in diameter than the holder's recessed hole). Quote
Members DrmCa Posted February 12, 2022 Members Report Posted February 12, 2022 They are used on scope rings. Can get them cheap on Aliexpress. I used to get them locally but the fastener chain instituted $25 min order so they no longer get my business, unfortunately. Quote
Members EMI Posted February 12, 2022 Author Members Report Posted February 12, 2022 (edited) Right. I've also got them from Aliexpress for around $2 a bag of 50 pcs. Even the locally available ones are made in china. Edited February 12, 2022 by EMI Quote
Members sewfix Posted September 7, 2024 Members Report Posted September 7, 2024 I am searching for a manual or copy for Pfaff 130 115 B Machine. Finding both the leatherworker forum posts and especially this thread very useful. I do want a sewing machine not a decorative object and would prefer to stick to the original needle bar and needle holder, in any case finding a normal Pfaff 130 needle bar as a replacement in 2024 Germany is probably only possible with willingness to tear a working good machine apart. Seems the 134 R series needle might be my best bet, probably with further adjustments. but still wondering if any newer information or tips are available. Quote
Members Constabulary Posted September 7, 2024 Members Report Posted September 7, 2024 Have you checked in this Forum: https://www.naehmaschinentechnik-forum.de/ Quote
