Members HayleyMcJenno Posted November 21, 2020 Members Report Posted November 21, 2020 I have a protex ty 3300 hoping someone can tell me how to make the presser foot higher to allow for more layers to go under ? My machine tec did change it last time he was here but am wanting it to go higher. I didn’t quite see which screw he loosened or tightened under the machine where the knee lift is. sorry I couldn’t upload a photo cause it tells me the file is to large. :l like every other photo I try to upload on here. Quote
Members Handstitched Posted November 22, 2020 Members Report Posted November 22, 2020 @Constabulary any ideas on this one? I'd would have thought if you put too many layers under the foot, it may exceed the machines capability ? On 11/21/2020 at 2:26 PM, HayleyMcJenno said: sorry I couldn’t upload a photo cause it tells me the file is to large You could always compress the image? HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Moderator Wizcrafts Posted November 22, 2020 Moderator Report Posted November 22, 2020 On 11/21/2020 at 1:26 AM, HayleyMcJenno said: I couldn’t upload a photo cause it tells me the file is to large Try using FastStone Photo Resizer. I use it often to reduce either the quality or actual pixel size to reduce the file size of images. It is also useful for equalizing one side of a group of photos to make a carousal display of images for web pages. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Constabulary Posted November 23, 2020 Members Report Posted November 23, 2020 (edited) I never have touched a machine of this type and brand. But looks a bit like the Juki DU-1181. I guess something should be mentioned in the manual. EDIT: I guess it is like this: https://www.manualslib.com/manual/1155862/Juki-Du-1181.html?page=12#manual Edited November 23, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
