Members MarlinDave Posted December 1, 2020 Members Report Posted December 1, 2020 Wondering where to order holster retention screws. Also, how do they work? A little spring involved? Quote
Members Dwight Posted December 1, 2020 Members Report Posted December 1, 2020 Just a note . . . suggestion . . . Mold your holsters tight enough that they do not need the retention screw . . . if you do a good job . . . it'll be a long time before it is needed . . . and they can be added afterwards. I don't use em because I know people . . . and some would tighten it down the first time they put a gun in the holster . . . and it would not be long until you would have to put a lariat on the gun to keep it in the holster as they ruined the molding. At least that is my way of doing things . . . YMMV. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members MarlinDave Posted December 1, 2020 Author Members Report Posted December 1, 2020 Thanks. So far I am only making holsters for myself. And I rarely run or tumble any more when packing. Quote
Lobo Posted December 1, 2020 Report Posted December 1, 2020 1 hour ago, Dwight said: Just a note . . . suggestion . . . Mold your holsters tight enough that they do not need the retention screw . . . if you do a good job . . . it'll be a long time before it is needed . . . and they can be added afterwards. I don't use em because I know people . . . and some would tighten it down the first time they put a gun in the holster . . . and it would not be long until you would have to put a lariat on the gun to keep it in the holster as they ruined the molding. At least that is my way of doing things . . . YMMV. May God bless, Dwight I agree. Retention screws really sound like a great idea, but in practice what invariably happens is that the retention screw is always being cranked tighter and tighter in an attempt to make it work as some think it should. The natural result is that the leather around the retention screw (and adjacent parts of the handgun, typically trigger guard area) will stretch with each application of pressure, then stretch more with the next application of pressure, until all possible adjustment is gone and all that is left are leather fibers stretched beyond any hope of providing retention. With some customers the end result may take several months, but with others only a matter of weeks will go by before they are ripping your rear end for making a "retention holster" that has no retention. As with many things in life and business, it is always best to be very careful what you promise to people. What you say, even the specific words that you use, mean far less than what the customer's perceptions might be. "But you said.................", "you advertised"..............., "I thought you meant............", and THE BIG ONE "Either you give me my money back or I'll tell everyone on the internet that you're a lying crook" (If you haven't heard that one yet, you probably will). Many people have an idea in their heads of what the "perfect holster" should be (usually after reading a couple of internet blogs and watching a You-Tube or two), and when their new holster doesn't match up with their mental image they immediately jump to the conclusion that the holster maker screwed up. By that point in the game there is not enough knowledge, wisdom, or common sense in the world to convince them otherwise. Another class graduates from "Holster Genius School" every week, every one of them filled with ideas and looking for someone to turn their little ideas into functional reality. Again, be very careful what you offer and how you describe it. Quote Lobo Gun Leather serious equipment for serious business, since 1972 www.lobogunleather.com
Members MarlinDave Posted December 1, 2020 Author Members Report Posted December 1, 2020 So is it just a screw? No spring, just washers? I am my only customer. Quote
Lobo Posted December 1, 2020 Report Posted December 1, 2020 9 minutes ago, 327fed said: So is it just a screw? No spring, just washers? I am my only customer. Typically there will be a washer of some type (rubber, leather, plastic) on the interior of the holster with a screw passing through to a fixed nut, from the front exterior to the rear exterior. Tightening the screw into the fixed nut compresses the washer and draws the leather more snugly together in the area of the installation. A machine screw and T-nut can be used, or a Chicago screw. Depending on the size of the screw-heads and nuts used a larger washer may be useful on both sides to avoid pulling through the holes in the front and rear holster panels. Quote Lobo Gun Leather serious equipment for serious business, since 1972 www.lobogunleather.com
Members MarlinDave Posted December 2, 2020 Author Members Report Posted December 2, 2020 Thank you. Quote
Members K5HEP Posted December 2, 2020 Members Report Posted December 2, 2020 (edited) A true retention screw will have a rubber washer in the middle - it is not just pinching the two pieces of leather together. They can work well if used correctly - they are not used to just retain the pistol in a holster, but are used adjust the degree that it is held.. For the average leather holster, they are not necessary, but can be useful in rare circumstances. Edited December 2, 2020 by K5HEP Quote
Members Josh Ashman Posted December 2, 2020 Members Report Posted December 2, 2020 As for a specific answer to your question, #8 machine screw, #8 T nut, a finish washer and a piece of fuel line just big enough for the screw to pass through and cut to the appropriate length for the "rubber washer". I get stainless or black oxide screws, T nuts (always stainless as they don't have black oxide ones) and finishing washers from McMaster-Carr by ordering online. They are fairly pricey but they deliver quick and have everything you need when it comes to fasteners. A decently stocked hardware store shoudl also have everything needed but you might have to settle for zinc plated in lieu of stainless. I generally agree with Dwight and Lobo as to whether retention screws are needed. At the same time there are cases where they are nice and I do put them in some holster types. I generally put mine in down at the end of the barrel for whatever that's worth. The pic below shows a screw at the bottom of the holster and 2 used to separate the mags in a double pouch. And as you have noted a number of times, it's for a personal holster so you can learn what you like and what works for you by experimenting. All the best, Josh Quote
