Members LK1 Posted January 23, 2021 Author Members Report Posted January 23, 2021 On 1/22/2021 at 4:14 AM, Frodo said: OK guys, I am going to try and tell you how to get your machines working go to this link here How To Thread & Set The Timing On Your Chinese Sewing Machine - YouTube if you have questions after seeing this, i can help you, i am not on this forum every day., pm me if it is the needle, put your finger under the machine, roll the crank, the neddle should tap your finger with out cutting you. if you do not feel the needle, it needs to be lowered, if it draws blood it is to long and the needle bar needs to go up This keeps on happening? As if the thread from the needle is trapping or catching and literally stops the machine from being cranked, What would I do to try and fix this? The thread sticking out the side of the bobbin in just loose thread thats come from the needle not the bobbin, it seems the bobbins thread is fine now Quote
CFM Frodo Posted January 23, 2021 CFM Report Posted January 23, 2021 PM SENT Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
kgg Posted January 23, 2021 Report Posted January 23, 2021 (edited) In your photo showing the bobbin. A couple of things I would check: When the needle picks up the thread through the bobbin cover. Can you pull the bobbin thread from the bobbin easily? Looking at the photo it appears the top thread has been stressed to the breaking point. I suspect the bobbin isn't threaded correctly. Thin thread (V69) should be threaded so it exits through the hole closest to the hook. Make sure the bobbin thread path through the hook assembly is correct. Goes through the bottom hole closest to the hook, under the tension spring and out the top hole closest to the hook. The thread has to enter one hole and exit the corresponding top hole. kgg Edited January 23, 2021 by kgg word error Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
CFM Frodo Posted January 23, 2021 CFM Report Posted January 23, 2021 LK, Look at 10:40 How To Thread & Set The Timing On Your Chinese Sewing Machine - YouTube in order to set the bobbin hook exactly where you want, loosen the pitman rod nuts and adjust the hook Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Members LK1 Posted January 24, 2021 Author Members Report Posted January 24, 2021 On 1/23/2021 at 4:48 PM, kgg said: In your photo showing the bobbin. A couple of things I would check: When the needle picks up the thread through the bobbin cover. Can you pull the bobbin thread from the bobbin easily? Looking at the photo it appears the top thread has been stressed to the breaking point. I suspect the bobbin isn't threaded correctly. Thin thread (V69) should be threaded so it exits through the hole closest to the hook. Make sure the bobbin thread path through the hook assembly is correct. Goes through the bottom hole closest to the hook, under the tension spring and out the top hole closest to the hook. The thread has to enter one hole and exit the corresponding top hole. kgg So should I change the enter and exit holes? The thread I’m using is T70#69 Bonded Nylon, and I haven’t had the bobbin tension down incase of it being too tight, here’s some pictures of the bobbin line 23 hours ago, Frodo said: LK, Look at 10:40 How To Thread & Set The Timing On Your Chinese Sewing Machine - YouTube in order to set the bobbin hook exactly where you want, loosen the pitman rod nuts and adjust the hook Watching now, thanks so much again @Frodo! Quote
Members LK1 Posted January 24, 2021 Author Members Report Posted January 24, 2021 On 1/23/2021 at 4:48 PM, kgg said: In your photo showing the bobbin. A couple of things I would check: When the needle picks up the thread through the bobbin cover. Can you pull the bobbin thread from the bobbin easily? Looking at the photo it appears the top thread has been stressed to the breaking point. I suspect the bobbin isn't threaded correctly. Thin thread (V69) should be threaded so it exits through the hole closest to the hook. Make sure the bobbin thread path through the hook assembly is correct. Goes through the bottom hole closest to the hook, under the tension spring and out the top hole closest to the hook. The thread has to enter one hole and exit the corresponding top hole. kgg Also yes I’ve just set up again from scratch after changing the pitman rods, and taking the loop for the bobbin line to come through was easy and just pulled right out?this was using the holes on the right though like the pictures above Quote
Members LK1 Posted January 24, 2021 Author Members Report Posted January 24, 2021 It’s either this problem or the needle going in and shredding it somewhere down at the bottom, I’ve tried the pitman rods made sure that’s all even and correct, just tried changing the bobbin holes closer to the hook and still nothing Quote
Members LK1 Posted January 24, 2021 Author Members Report Posted January 24, 2021 24 minutes ago, LK1 said: It’s either this problem or the needle going in and shredding it somewhere down at the bottom, I’ve tried the pitman rods made sure that’s all even and correct, just tried changing the bobbin holes closer to the hook and still nothing Success!! Ive just had it doing running stitches fast and slow through 3 different types and thickness of leather and material, all without snapping or having any hiccup! I don’t want to get too ahead of myself but since the initial set up I’ve not had it this dialled in until now! All with great thanks to the leatherwork community and especially @Frodo! @kgg And the others that have been willing to help! I’ll be back tomorrow after I’ve started a few projects that have been on hold and let you guys know how the machine and the leatherwork is going! Again it’s much appreciated for all the help guys, I’ll keep this post live for anyone else with similar issues, and hopefully I won’t be back with bad news! Thanks again guys! Quote
CFM Frodo Posted January 25, 2021 CFM Report Posted January 25, 2021 the needle MUST go down Then the hook sweeps in front of the hook grabbing the thread on the NEXT revolution when the needle comes up it MUST come up in the corner opposite the hook Also..what needle size and thread size are you using? incorrect needle will cut thread also Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
CFM Frodo Posted January 25, 2021 CFM Report Posted January 25, 2021 Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
