Members JeremyG Posted January 14, 2021 Members Report Posted January 14, 2021 So I've been getting the hang of card holders and wallets. I'm trying to move up to long wallets with zippers and multiple rows of card pockets and I'm running into some trouble. What I normally do is attach my t pockets onto a larger piece of leather that will in itself become a pocket as well. So when I make my patterns, I give the edges of my t pockets an extra 1/8" on either side. Then, after I've sewn on each pocket, I can trim off the excess and then finish the edges. That's the idea, anyway. The issue is the bulk. Even when I skive as much as possible in the appropriate areas, I can just barely get the pockets to sit down on the main piece of leather by the time I get to the third or fourth one. This this leads to poor glue adhesion along the edges because the pockets are hardly even touching the base, which then also leads to sloppy stitch lines, and therefor uneven stitches. I've included some pictures to try and make what I'm talking about more clear. What bothers me is I see folks on youtube go through this process with no bulk issues what so ever. Look at this video for example: https://www.youtube.com/watch?v=-UEauYrGzAE&t=346s Skip to 4:40. This guy doesn't even give himself any extra trim allowance, and he even pre-punches every piece of leather so they have to line up PERFECTLY. And he just goes along and slaps them right on with no alignment issues, no trimming, no bulk, nothing. Does he maybe make each pocket slightly wider than the last so they all just line up? Do any of you do that? Seems like that would be really hard to get right. Any advice on this topic would be much appreciated. Thank you. This link will take you to the pictures of what I'm talking about. I had to use a link because the file sizes were too big to upload them directly. https://docs.google.com/document/d/1Z3bio0Yub_EJYTLHcxcJELhUux8t0nYlbgrhRQqTwPQ/edit?usp=sharing Quote
Members mike02130 Posted January 14, 2021 Members Report Posted January 14, 2021 How thick is your leather? He's using 1.2mm for the pockets. How wide and thin is your skive? Looks like it may be too narrow(?). Quote @mike02130 Instagram
garypl Posted January 14, 2021 Report Posted January 14, 2021 I would trim the pockets a bit more under the tabs - looks like it might only be @1/4" from edge of pocket to the edge of the wallet - not much room to glue the next pocket. I usually make the tabs at the top of each pocket @1/2" from the edge of the tab to the start of the pocket body - gives you plenty of gluing area for each tab. Does this make sense? Quote Cowboy 4500, Consew 206RB-4
Northmount Posted January 15, 2021 Report Posted January 15, 2021 11 hours ago, JeremyG said: This link will take you to the pictures of what I'm talking about. I had to use a link because the file sizes were too big to upload them directly. https://docs.google.com/document/d/1Z3bio0Yub_EJYTLHcxcJELhUux8t0nYlbgrhRQqTwPQ/edit?usp=sharing Please post your photos here. 3rd party hosting often results in photos disappearing due to hosts changing policies, or users moving, deleting, etc. If your photo are too large, reduce the file size. There are lots of suggestions as to how you can reduce file sizes here. 800x600 pixels is adequate for most. 1024x768 is a bit better. Either of these will allow you to post many photos. It is also a favour to users on the fringes of good internet access. They don't have to wait an hour or so for a couple large photos to download before they can view the post. Please refer to this thread to find several pieces of software or web based utilities to help you. Quote
