Just wondering if anyone has put a servo motor on a BUSM / peirson # 6 machine?   Did a search and no luck.
Edited by catskin
spelling
From the number of responses kind of looks like I might be the first to try.
I once owned a BUSMC / DVSG  #6HM and played with the idea of motorizing it (actually never did) I talked to LW Member SINGERMANIA back then and he said you can add a servo. But to be honest I personally would go with a clutch motor because the machine flywheel is quite heavy and the servos only have an electronic brake whereas the clutch motors have large mechanical brake. I think the clutch motor brakes are more durable and may last longer in the long view. But that's just my opinion. ;)
I actually have a clutch motor on it.  But have not sorted out how to make a convenient lever for engaging it. With my speed reducer it goes at a reasonable speed.  Just thought the variable speeds with a servo would be nice. I would add a picture but seems the one picture I posted a long time ago took up all my allowance.
Try contacting this forum member.. they may some pointers....
I'm still deliberating over motor powering one of mine.
