Members Rosch22 Posted May 6, 2021 Members Report Posted May 6, 2021 Dear fellows, I rescued a nice little machine called Pfaff 138 short before it went to the scrap yard. The special on this thing is, that it is driven by an 250 watts moretti motor, which sews like a bee flying over flowers, so smooth and nice, driven just by transport from below. With a dial in the middle of the top, a switch from straight to Zigzag sewing is possible. The only flaw I can find is, that the hook is missing some stitches, which could be solved quiet easily, if there wouldn't be that feature, that also twin needles can be plugged in. So I would like to do the timing by the books. Does any one of You guys own a SERVICE MANUAL for this machine ?? Thank You. Quote "A stitch in time saves nine."
Members Constabulary Posted May 6, 2021 Members Report Posted May 6, 2021 (edited) Maybe this file will help you. Thats at least what I have... Adjustment Pfaff 138.pdf EDIT: Just noticed you are from Germany so so check this one SM_PFAFF+138-130-230-238-einstellanleitung.pdf Edited May 6, 2021 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Rosch22 Posted May 6, 2021 Author Members Report Posted May 6, 2021 Suppi...Danke !!!! Quote "A stitch in time saves nine."
Members mbagg Posted June 22, 2025 Members Report Posted June 22, 2025 @Constabulary would you mind re-uploading the P138 manual? Thank you! Quote
Northmount Posted June 22, 2025 Report Posted June 22, 2025 5 minutes ago, mbagg said: @Constabulary would you mind re-uploading the P138 manual? Thank you! Just scroll back up a couple posts and it is right there, still available. Just downloaded it to test, it downloads just fine. Quote
