Members YinTx Posted June 17, 2021 Members Report Posted June 17, 2021 Barely used alcohol lamp for heating creasers. I ended up with an electric crease shortly after getting this, and have since sold my Wuta Creasers that I bought at the same time. $10 plus shipping YinTx
Members JayEhl Posted June 17, 2021 Members Report Posted June 17, 2021 Hi, What are the differences/advantages if I use alcohol burner v gas burner on the stove?
Members YinTx Posted June 17, 2021 Author Members Report Posted June 17, 2021 1 hour ago, JayEhl said: Hi, What are the differences/advantages if I use alcohol burner v gas burner on the stove? Don't know, as I don't have a gas burner stove in my current home. But, I do know if you use denatured fuel alcohol, it will not blacken your tools. Also, you can put the lamp on your work bench, and it presumably uses a lot less fuel. Imagine the flames burn at different temperatures as well. I have seen leather workers set their crease on an electric hot plate with success, so that is an option. $10 pretty cheap if someone wanted to experiment. YinTx
