On 6/20/2021 at 6:28 PM, ButtonLady said:
I third this suggestion.  When I was ready for an industrial, I made an appointment with a dealer and showed with a bag stuffed with typical fabric.  If a dealer isn't comfortable with you test driving some machines... find another dealer.
I would love to visit a dealer and look at all the options. Sadly I am quite a distance from most and the one closest to me has very poor reviews. I am currently on a road trip and might have an option to look at a Ludwig cylinder arm machine tomorrow. I think that will give me a better idea of whether or not a cylinder arm will benefit me or not.
15 hours ago, MtlBiker said:
@homesewnrose - Funny, those are the exact same two machines I started with.  I liked the Brother 6000i, but it just wasn’t strong enough for what I wanted to do.  I replaced it with an HD3000 which I still have and use.  But I only use it for very light sewing, such as masks, etc. and light repairs.  It’s a surprisingly good machine.  As I got more involved with sewing, using more webbing, heavy canvas, Cordura, etc. and many layers, I found I needed something a lot more powerful.  Not knowing much about industrial machines, by luck I came across a dealer demo Consew 206RB-5 at a good price and now after more than a year using it, I LOVE IT!  That’s a flatbed machine.  I’m sewing primarily with v92 threads and use 135x17 needles for most fabric (usually size 20) and 135x16 for leather.  (I’m just getting into leather but don’t have much experience yet.)
About 6 months ago I added a cylinder bed machine, a Techsew 2750 Pro.  And that’s really a nice machine also.  But as KGG said earlier in this thread, it’s pretty hard (impossible?) to find one machine that does everything.   I use the Consew for the vast majority of my sewing but the cylinder bed machine is great for sewing the openings of bags (which I’m making mostly these days).
Now, after the few months of experience I have, if I had to choose only one machine, it would be the Consew 206RB-5 (or equivalent).  That’s the one machine I really couldn’t do without.
Best of luck with your search!
Too funny.
Do you have the flat bed table attachment for your cylinder arm machine? I just see the versatility of it being so helpful!
If you look at walking foot machines, be aware that the triple (compound) feed machines have an oblong hole or slot in the center of the feed dog. This allows for the moving needle to flex under load without hitting metal. The larger the hole, the more likely soft material will get pushed into it. Even if the hole in the feeder isn't a problem, the large rectangular cutout in the throat plate can trap soft material.
To avoid these issues, look at dual feed walking foot machines that have top and bottom feed with a static position needle.  The bottom feed is via dual row feed dogs and the top is via teeth on the presser foot. These machines usually have optional throat plates with larger or smaller needle holes. If you only plan to sew with thread up to #92, the largest needle will be a #19 or #20. The hole in the needle plate can be about 1.5 to 1.75 mm diameter and still clear a threaded #20 needle. In contrast, the hole in a heavy duty triple feed machine could be as much as 2.5mm wide and 4mm long.
Seeing as how you aren't sewing leather, the teeth on the feet won't be a negative option. There are plenty of dual feed walking foot machines to be found. The alternating feet will walk up and down over different levels at overlapping seams.
Posted IMHO, by Wiz
8 hours ago, homesewnrose said:
Too funny.
Yes, with the PRO version of the Techsew 2750, the flatbed attachment came with it.  But I've never even tried to install it.  It's the kind of thing that you'd need to set up and adjust and then leave it in position rather than quickly change back and forth  (as you might have to do when working on a bag).  Since I do have a flatbed machine (the Consew 206RB-5) I really don't need to use the flatbed attachment for the Techsew.  When I'm working on a project, I might move back and forth between the cylinder bed machine and flatbed several times per hour, depending on what I'm doing.  And it would be too cumbersome if I only had the Techsew and had to install and remove the flatbed attachment.  I got the PRO version mainly for the accessories like laser guide, swing-down guide, speed reducer, etc.
Current machines: Janome HD3000 and Skyline S5, Consew 206RB-5, Singer Profinish serger, Techsew 2750 PRO, Sailrite LSZ-1 Premium, Consew DCS-S4 Skiver
I second this. I also have a Techsew, a 2700, that came with a table attachment. And, my Cowboy CB4500 came with a table attachment. I have flatbed machines that are better suited to sewing flat items and never use the table attachments. But, I am in the sewing business where time is money and customers often watch and wait while I sew their stuff. If one has plenty of time and is not in a hurry, and doesn't have customers watching and waiting, a table attachment would be a convenience as opposed to buying two machines.
Posted IMHO, by Wiz
Yes, my thought is to try out the cylinder machine with the table attachment. I am a stay at home mom with three boys and I don't get a lot of sewing time unless they are in school. I figure this would work well for now until I can afford, space and monetary wise, another machine. My Janome HD 3000 is actually a great machine that works well for my lighter weight items that I would need done on a flatbed. Space is actually my biggest limitation right now.
Ok, this is good to know. The cobra 26 series is a compound feed machine. I will have to do more research in this area. I most likely will only be sewing thin material on here when it is layered with thicker fabric. My outer fabrics won't be an issue, but my liners are sometimes much thinner. Do you think it will be an issue when layered, or just when sewing thinner fabrics by themselves?
Thanks for ALL your help! :)
To help you visualize the differences of how the Juki 1181N and Juki 1541S handle Light, Medium and Heavy material I here are two links which might help. Also a link that details the difference between the compound feed Juki 1541S and the Juki 1508.
i.    Juki DU-1181N (walking foot) sewing Light, Medium and Heavy fabric     www.youtube.com/watch?v=IKJuKTrjsbw
ii.   Juki DNU-1541S (compound feed) sewing Light, Medium and Heavy fabric     www.youtube.com/watch?v=4JES-2I7h3o
iii.  Juki DNU-1541S versus Juki LU1508  (both machines are compound feed)       www.youtube.com/watch?v=SWvi1wYfc9A
kgg
If your current machines didn’t break needles and had more power to sew threw thicker seams would that solve your problem?
If so, you may just want to get an industrial flat bed without a walking foot.   Juki ddl 8700 machines are well under $1000 brand new.   On the used market they often sell for $400 in new condition with servo motor.   If you have more time than money, the older ddl machines like 555, 5550, 8300, 870 sew just as well as the new ones - I’d say a made in Japan ddl 555 in good shape is even better than one of the new ones that are made in China - and these crop up for under $200.   Unfortunately the older ones typically won’t have a servo unless it’s been replaced, and the older tables definitely look more dated than a nice white one from a 870 or 8700.
On the used market, if you wait for one of a average price or below, there is no reason you can’t use it for a year or two and turn around and sell it for as much as you purchased it for.
Any of these, or similar machines from other manufacturers, are a huge bang for the buck and a great way to get your feet wet.
