Members LomaeArts Posted June 27, 2021 Members Report Posted June 27, 2021 I would like to add a binding plate to my bigger sewing machines. on the 45k, I believe the Guide plate is P/N91168 and the screws fixing the plate are P/N #180f. can any one confirm these are 3/16 x 28tpi screw? What would be the screw needed to attach the binding plate? would these screws also fit the 132k6? Thank you Matthew Quote Sewing Machines I own: Singer 29K58, Singer 29k72, Singer 45K25, Singer 132k6, Singer 411U967, Singer 5523, Singer 31k20, Pedersen Model 308, Landis 12 Out Sole Stitcher, Pedersen Blake stitcher, Chinesium Boot patcher
Members Constabulary Posted June 27, 2021 Members Report Posted June 27, 2021 (edited) They are pretty much all the same. Singer, Seiko, Juki... were using this type of screws on basically all industrial sewing machines. They differ in length sometimes. I even use them for attaching presser feet to the needle bar on my 45D91 https://www.college-sewing.co.uk/50190-long-thumb-screw.html Edited June 27, 2021 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Constabulary Posted June 27, 2021 Members Report Posted June 27, 2021 (edited) Forgot - this is the screw for attaching the plates: https://www.college-sewing.co.uk/1381-needle-plate-screw-singer-132k.html Edited June 27, 2021 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members jimi Posted June 28, 2021 Members Report Posted June 28, 2021 On 6/27/2021 at 5:48 AM, LomaeArts said: can any one confirm these are 3/16 x 28tpi screw? Sorry i dont have any screw gauge for measuring, and yes the plate for the 45k and the 132k are the same and use the 793d screw to fix the guides on. The 45k had its binder but is pretty tricky to use, unlike the new type binders this one needs a bit more practice, on my side, as it likes to wander off to the side as there is nothing underneath to guide it. The foot for this has a step and you also have the small spring metal guide to adjust the width and guide it , maybe the needle plate 85529 with the step further over could work?? Quote
Members jimi Posted June 28, 2021 Members Report Posted June 28, 2021 i definitely need more practice with this one!! Quote
