Members JayEhl Posted July 28, 2021 Members Report Posted July 28, 2021 I bought a used techsew 2700 and after taking it home and figuring out the threading I noticed a bit of string hanging out the back. I removed the plate and this is what I saw!! Is this important and is it easy to fix? Quote
Moderator Wizcrafts Posted July 28, 2021 Moderator Report Posted July 28, 2021 Those are oil wicks. Please stick them back inside the head and make sure they contact the needle bar and inside foot bar. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
kgg Posted July 28, 2021 Report Posted July 28, 2021 9 hours ago, JayEhl said: I bought a used techsew 2700 and after taking it home and figuring out the threading I noticed a bit of string hanging out the back As wiz said they are the oil wicks. If you email Techsew they probably would email you a copy of their manual which should help you with routing the wick to the correct locations. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members JayEhl Posted July 28, 2021 Author Members Report Posted July 28, 2021 9 hours ago, Wizcrafts said: Those are oil wicks. Please stick them back inside the head and make sure they contact the needle bar and inside foot bar. Oh, man, you don't know what kind of a relief it was this morning when I read that! I was groaning a bit last night when I went to bed. Thank you so much! 1 hour ago, kgg said: If you email Techsew they probably would email you a copy of their manual which should help you with routing the wick to the correct locations. Oh, fantastic. I got a manual from the previous owner so if it's not detailed in there, I'll go official Tech Sew route. But that all said, I am super excited about the machine. After I got it all set up, the thread she gave me (207) was too big for the needle that was already in the machine so I was unable to play with it as I had hoped. I'm going to see if the wife will be able to pick up some smaller thread size and needles at a local store. Quote
kgg Posted July 28, 2021 Report Posted July 28, 2021 8 minutes ago, JayEhl said: I'm going to see if the wife will be able to pick up some smaller thread size and needles at a local store. Depending on your local store but if they are like most they will typically deal mostly with domestic sewing machine related items. For needles I would recommend you check out Wawak, good prices and fast delivery. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members JayEhl Posted July 28, 2021 Author Members Report Posted July 28, 2021 Okay cool. I'm checking out the site now. thanks! Quote
Moderator Wizcrafts Posted July 28, 2021 Moderator Report Posted July 28, 2021 2 hours ago, JayEhl said: After I got it all set up, the thread she gave me (207) was too big for the needle that was already in the machine I do not recommend using #207 thread in that machine. I have the same machine in my shop and limit it to #138 maximum, using a #23/160 needle. The 2700 is normally used with thinner thread, like #69 and #92. It is not strong enough to regularly punch through with #207 thread. But, if you really want to use that thread, get some System 135x16 (leather pt) or 135x17 (round pt) needles in size 24. Just make sure you understand how to re-time the needle bar to the hook after you knock it out of time. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members JayEhl Posted July 28, 2021 Author Members Report Posted July 28, 2021 Thanks so much for your guidance @Wizcrafts. Since you have this machine, and your experience and knowledge base is valued, I would much rather go with what you're using. Would you mind sharing name brands? (PM if it would be more appropriate to share this with me, privately). ~JL Quote
Moderator Wizcrafts Posted July 28, 2021 Moderator Report Posted July 28, 2021 1 hour ago, JayEhl said: Thanks so much for your guidance @Wizcrafts. Since you have this machine, and your experience and knowledge base is valued, I would much rather go with what you're using. Would you mind sharing name brands? (PM if it would be more appropriate to share this with me, privately). ~JL I buy thread from different stores. Most of it comes from our Cowboy sewing machine dealer. Others come from Superior Thread, or Wawak. I still have some Weaver bonded nylon thread, but is very twisty and expensive. Your machine uses the ubiquitous system 135x16 and 135x17 needles. They are sold everywhere industrial sewing machines are sold and serviced. I buy some Japanese needles on eBay that are titanium coated and like them just fine. But, now and then I want something a little better made and buy Schmetz or Groz Beckert needles. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members JayEhl Posted July 28, 2021 Author Members Report Posted July 28, 2021 Wow, thanks for this information, especially about the 135x16 and 135x17 needles. There is a local place on the other side of downtown that I am going to see what I can pick up (so i can start playing with my new toy right away! ) Thanks! Quote
