Members jadub Posted August 31, 2021 Members Report Posted August 31, 2021 Hi, I have a Pfaff 1245 with what appears to be tension issues. The bobbin thread won’t snug up unless I have the top tension so tight every knot is pulled through and the top thread basically lies flat across the leather. If the knot sits somewhere in the middle of the leather the bobbin thread is loose and even a little wobbly. Thank you for your help! Quote
Moderator Wizcrafts Posted August 31, 2021 Moderator Report Posted August 31, 2021 First, try flipping the bobbin around, reversing the bobbin thread's direction. I usually feed my bobbin thread against the direction of the slit under the spring. This ensures that the thread goes and stays under the tension spring. But, if the thread is difficult, feeding it inline might help. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
kgg Posted August 31, 2021 Report Posted August 31, 2021 2 hours ago, jadub said: Hi, I have a Pfaff 1245 with what appears to be tension issues. This could be also be related to the size of needle, size of thread, thickness of leather. What size needle, thread and thickness of leather are you using? kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members jadub Posted August 31, 2021 Author Members Report Posted August 31, 2021 I have switched the bobbin thread direction. Yesterday it came to me in a flash that maybe I had it in wrong. No luck. Still wonky. The needle is a 130/21 with 138 thread. I believe it may be pushing it but within spec. The leather thickness varies as I sew the wallet depending on how many layers are being sewn. Not more than1/4” at the most. Thank you for the thoughts. I really appreciate it. Just so you know, I’ve also tried different thread, a different needle, rethread the machine, new thread in bobbin and maybe a couple of other things. Today I had it working on several lines of test stitching but I sewed a wallet and the bobbin side was wonky again. Quote
kgg Posted August 31, 2021 Report Posted August 31, 2021 22 minutes ago, jadub said: The needle is a 130/21 with 138 thread. I believe it may be pushing it but within spec. My understanding is the 130/21 needle is used for the top end of V92 thread while a #22 needle is the bottom end of V138 thread. I would suggest you try V92 thread with the #21 and see what happens or move up to a #22 needle. Also I am assuming you using a older PFAFF 1245 and using the correct needle for your sub class which would be either 134 -35 needle system or a 190 needle system in a leather point not a fabric point needle. As a note the older PFAFF can only accept a 140 / #22 needle with a max thread of 15/3 which is about T120 depending on thread type (cotton vs bonded polyester vs bonded nylon) and thread manufacturer this I think may cause problems with V138 particularly when used in both the bobbin and as a top thread. You maybe able to use V138 as a top thread but be limited to V92 in the bobbin depending on the material being sewn. Having the top thread lay flat on top of you material indicates the upper tension is too tight or the lower tension is too loose. You did say the bobbin is loose and wobbly. Have you done adjusted the bobbin tension by doing the drop test. Note the tension screw only needs to be turned in ever so slight increments like an 1/8 of a turn. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members jadub Posted September 1, 2021 Author Members Report Posted September 1, 2021 Thank you for the response kgg. I’ve been using The Thread Exchange for needle and thread sizing. Here they show 138 working with needles from 125/20-140/22 unless I’m reading it wrong. It wouldn’t be the first time. I’ve actually taken the machine to 3 technicians for service and they say my setup is okay. Of course each time the machine only works for a short time after they’ve worked on it before I have trouble again. Quote
kgg Posted September 1, 2021 Report Posted September 1, 2021 1 hour ago, jadub said: Here they show 138 working with needles from 125/20-140/22 unless I’m reading it wrong. Yes you are reading the chart correctly but I think most of the charts are meant for sewing in fabric rather then leather or sticky material. You may find the chart by Toledo Sewing Machines (www.tolindsewmach.com/thread-chart.html ) a better choice. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Moderator Wizcrafts Posted September 1, 2021 Moderator Report Posted September 1, 2021 The chart that shows a #20 or 21 needle for use with #138 thread would only work if the bobbin thread is a size smaller. Thus, you could have #138 on top with #92 in the bobbin. The bobbin tension would need to be increased to keep the knots from showing on top. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members jadub Posted September 1, 2021 Author Members Report Posted September 1, 2021 Wow, thank you guys! I’ll give that a try. I would be so happy if this worked out. I already ordered 140/22 needles. Can’t wait to give them a go. Quote
Members jadub Posted September 3, 2021 Author Members Report Posted September 3, 2021 Thank you for the input. Got my new needles this morning and tensioned my machine accordingly and it’s much better. I also finally realized I was using junk thread I had accidentally bought. Compared to the thread brands sold by Thread Exchange, Amman, A and E and Filtec, there is a clear visual and tactile difference. Filtec is even a little less stiff than the other two. I know this is a frequent question but since the thread was a big part of my problem. Does anyone have a favorite brand of bonded nylon they want to mention here? Thanks again! Quote
