Members DJole Posted October 27, 2021 Members Report Posted October 27, 2021 (edited) Just finished this up last night. Here's the outside with the tooling pattern completed: And here's the completed piece: I used Angelus Light Brown dye on this piece. Edited October 27, 2021 by DJole Quote \D. Jole \ --> <http://djole.altervista.org/djole/Publications/Leather/Lindex.htm>
Members DJole Posted October 27, 2021 Author Members Report Posted October 27, 2021 A view of the inside: Black Tokonole on the edges, light brown Ritza thread, and some nice red leather from a remnant sale. Quote \D. Jole \ --> <http://djole.altervista.org/djole/Publications/Leather/Lindex.htm>
Members PastorBob Posted October 28, 2021 Members Report Posted October 28, 2021 Nice job on tooling. Love the red contrast on the inside. What thickness thread did you use and what size stitching forks did you use? Quote In God's Grace, Pastor Bob "While we were yet sinners, Christ died for us." - Romans 5:8 www.PastorBobLeather.com YouTube Channel
Members DJole Posted October 28, 2021 Author Members Report Posted October 28, 2021 On 10/28/2021 at 11:21 AM, PastorBob said: Nice job on tooling. Love the red contrast on the inside. What thickness thread did you use and what size stitching forks did you use? Expand Thank you-- I worked hard to get good lines on the tooling pattern. The thread is Ritza Tiger 0.6. The stitching chisels are Japan Goods 3mm. In a couple places (where the leather stacks up in multiple layers) I also used Kevin Lee 3mm reverse irons to make sure the lines were straight. I discovered that to get the stitching lines straight, as I was pounding from the tooling side down, I needed to hold the chisel a couple degrees slanted from vertical, since the thickness of most of the red pocket leather doesn't go all the way to the edges. I also cut the interior pocket pieces (and their backing) a bit bigger so that I could trim them all after stitching, so I have a nice, even edge. Quote \D. Jole \ --> <http://djole.altervista.org/djole/Publications/Leather/Lindex.htm>
Members HandyDave Posted October 30, 2021 Members Report Posted October 30, 2021 Good looking wallet. I really like the tooling and the pebbled red pockets. Theres only one thing i see and my eye just keeps going to it is that one bottom corner where the stich goes at angle where there aint a hole right in the corner like the other ones. My corners and intersection lines i allways stab first then feel in my holes in between. Other then that one corner its a great piece. Quote
Members DJole Posted October 30, 2021 Author Members Report Posted October 30, 2021 On 10/30/2021 at 12:28 AM, HandyDave said: Good looking wallet. I really like the tooling and the pebbled red pockets. Theres only one thing i see and my eye just keeps going to it is that one bottom corner where the stich goes at angle where there aint a hole right in the corner like the other ones. My corners and intersection lines i allways stab first then feel in my holes in between. Other then that one corner its a great piece. Expand I noticed that too. It's the only corner where the holes just don't quite line up right! ;-) That's a good tip to start from the corners, and get those even, and then maybe have a slightly longer stitch in the middle of the straight line. Quote \D. Jole \ --> <http://djole.altervista.org/djole/Publications/Leather/Lindex.htm>
Members PastorBob Posted November 1, 2021 Members Report Posted November 1, 2021 On 10/28/2021 at 6:55 PM, DJole said: Thank you-- I worked hard to get good lines on the tooling pattern. The thread is Ritza Tiger 0.6. The stitching chisels are Japan Goods 3mm. In a couple places (where the leather stacks up in multiple layers) I also used Kevin Lee 3mm reverse irons to make sure the lines were straight. I discovered that to get the stitching lines straight, as I was pounding from the tooling side down, I needed to hold the chisel a couple degrees slanted from vertical, since the thickness of most of the red pocket leather doesn't go all the way to the edges. I also cut the interior pocket pieces (and their backing) a bit bigger so that I could trim them all after stitching, so I have a nice, even edge. Expand Thanks...I have the 3mm forks, but only have .8 and 1mm threads....gonna have to increase my thread inventory. Again, nice job! Quote In God's Grace, Pastor Bob "While we were yet sinners, Christ died for us." - Romans 5:8 www.PastorBobLeather.com YouTube Channel
Members DJole Posted November 1, 2021 Author Members Report Posted November 1, 2021 On 11/1/2021 at 1:20 PM, PastorBob said: Thanks...I have the 3mm forks, but only have .8 and 1mm threads....gonna have to increase my thread inventory. Again, nice job! Expand I bought the thread from Rocky Mountain Leather Supply, who will make 25 meter spools for about 7 dollars apiece, with free shipping. Good folks there. Quote \D. Jole \ --> <http://djole.altervista.org/djole/Publications/Leather/Lindex.htm>
