Members evilblackdog Posted October 28, 2021 Members Report Posted October 28, 2021 (edited) https://drive.google.com/file/d/1fvULpiqfekBmnI34rr7vofxQXf8aUN3F/view?usp=sharing I'm looking into the process of reverting this back to a standard manual machine. Does anyone have experience and could tell me how difficult it is or what is all entailed? Edited October 29, 2021 by Northmount Downloaded and posted photo in. Quote
Northmount Posted October 29, 2021 Report Posted October 29, 2021 19 hours ago, evilblackdog said: https://drive.google.com/file/d/1fvULpiqfekBmnI34rr7vofxQXf8aUN3F/view?usp=sharing Please post your pictures here. Third party hosting often results in the link being broken by changes in permissions, files moved, deleted, etc. It then makes the thread useless to those that come along later. Quote
Members evilblackdog Posted October 29, 2021 Author Members Report Posted October 29, 2021 2 hours ago, Northmount said: Please post your pictures here. Third party hosting often results in the link being broken by changes in permissions, files moved, deleted, etc. It then makes the thread useless to those that come along later. I certainly would have but the max total file size of 1.46MB makes that a bit less convenient. Quote
Northmount Posted October 29, 2021 Report Posted October 29, 2021 17 minutes ago, evilblackdog said: I certainly would have but the max total file size of 1.46MB makes that a bit less convenient. There are plenty of options to reduce file size easily and conveniently. See this thread for help with resizing photos. https://leatherworker.net/forum/topic/15122-how-to-post-pictures-on-lw/?do=findComment&comment=551171 Life isn't all about convenience unfortunately. Quote
Members evilblackdog Posted October 29, 2021 Author Members Report Posted October 29, 2021 8 minutes ago, Northmount said: There are plenty of options to reduce file size easily and conveniently. See this thread for help with resizing photos. https://leatherworker.net/forum/topic/15122-how-to-post-pictures-on-lw/?do=findComment&comment=551171 Life isn't all about convenience unfortunately. Do you have any recommendations for multi picture albums? Do you prefer a separate post for every 2 pictures? Quote
Northmount Posted October 29, 2021 Report Posted October 29, 2021 4 minutes ago, evilblackdog said: Do you have any recommendations for multi picture albums? Do you prefer a separate post for every 2 pictures? If you reduce the size to 800x600 or even to 1280x768 pixels, you have room for a hundred or more files in one post. Quote
Members dikman Posted October 29, 2021 Members Report Posted October 29, 2021 As I said in your other thread it shouldn't be difficult to remove everything that's an add-on to the machine and just leave the basic head unit on the table. All you've got is a 335 that has had the Efka stuff added to give it specific functionality. More photos, and closer, will help to clarify things. As for any solenoids/air lifters they are only added for the automation, the 335 didn't come with them as standard. The reverse may have only been blocked from working due to the automation and may still be there, again photos will help. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members evilblackdog Posted October 30, 2021 Author Members Report Posted October 30, 2021 17 hours ago, dikman said: As I said in your other thread it shouldn't be difficult to remove everything that's an add-on to the machine and just leave the basic head unit on the table. All you've got is a 335 that has had the Efka stuff added to give it specific functionality. More photos, and closer, will help to clarify things. As for any solenoids/air lifters they are only added for the automation, the 335 didn't come with them as standard. The reverse may have only been blocked from working due to the automation and may still be there, again photos will help. Here's a video I just made. If you need a close up of something to give an opinion I'm happy to oblige. Thank yoy for the help! https://www.youtube.com/watch?v=VlNNeRkJq_Y Quote
Northmount Posted October 30, 2021 Report Posted October 30, 2021 Many of the walking foot machines use the forward and reverse to adjust the stitch length. That air gizmo on the top back and the control box may do the forward and reverse plus stitch length, thus no lever required. Search for Manuals for these machines. Of course my machine is not a PFAF so can't provide much more help than this. Have fun while sorting this out! Quote
Members dikman Posted October 30, 2021 Members Report Posted October 30, 2021 (edited) Impressive. I've only seen photos of Efka units on machines, and no details. Edit: manuals here - https://www.manualslib.com/products/Pfaff-335-3541803.html It's the "new" model, btw, not the old casting. It will show you what the missing reverse/stitch length lever looks like and you should be able to work out what the various added-on bits do. Those levers on the back would have been added to allow for the automation of foot lift and maybe tension? Usually the mounting hole spacing for clutch motors follows a standard 3-hole pattern and a servo should line up with the same holes. The only real problem I see is finding the replacement stitch length lever. Because the 335's were sold as "plain" machines there's no reason this one can't be returned to that state. Edited October 30, 2021 by dikman Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
