What is the difference in thread size for the standard hook #33-B1830-563-0A0 and the heavy thread hook #42-B1830-563-BA0 that is used in the
LU-563?
All I have found out about the differences is that the light/medium duty hook takes M style bobbins, which holds approximately 1.58x more thread than the G style bobbins that are used in the Singer 111 walking foot machines upon which the Juki LU-562 and 563 were cloned.
In contrast, the heavy duty 563 hook takes U style, double capacity (2x) bobbins. This difference in capacity is based upon the standard G size bobbin which is regarded as 1x capacity in a Singer 111 walking foot machine.
Posted IMHO, by Wiz
LU-563?
The standard hook will work better with thinner home size thread & the heavier duty one doesn't have the little tang (finger)on the gib that will allow the thicker thread to release easier off it.We used to grind the tang off the standard ones when people wanted to sew heavier material with thicker thread.You can see the standard one in the pic on the  left.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Thanks Wizcrafts & CowboyBob for explaining that.
  • 2 months later...
I have a 111w155 that I believe has been converted to large bobbin ( size U 28x11mm  not the m size), need to replace the hook,  from what I can find out I believe the correct part comes from a juki LU-563 , part no.B1830-563-OAO or B1830-563-BAO , they both look like mine, mine has the tang on it, but uses the "U" style (28x11mm) bobbin , the parts I looked up say the use large "M" bobbin , not the "U", something is not adding up, any help would be great , thanks
Contact @CowboyBob about this. Or, start a new topic and wait for a professional dealer to reply. Yours is now a non-standard machine. I also have a Singer walking foot machine that @CowboyBob converted to use a Juki U bobbin. He knows the parts and alterations involved in this conversion.
Posted IMHO, by Wiz
We always use the HD hook w/o the tang for heavier sewing B1830-563-BAO
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
thanks for the input,      is ,there good place to order this part ,or should I just search amozon and ebay,  also am I correct in assuming that both parts use the "U" size bobbin(28x11mm),just want to make sure, I already ordered and returned one, was the original part for this machine before being converted, I did not know it was changed over and just looked it up in the parts list , thanks for the help.
@CowboyBobprobably has that hook in stock. Call him and ask. The phone number is in his signature.
Posted IMHO, by Wiz
