15 hours ago, Wykoni said:
Will order some, let me ask you a question, I will be making holsters, the doubled thickness will be about 16 oz will the 207 be ok for that?
Number 207 thread is a fairly strong thread. I use it to sew suede lined rifle slings and guitar straps that total about 9 to 12 ounces. It can sew 8 ounces but it is a little tricky to hide the knots. These items don't place much strain on the thread; it just holds the layers together.
Handgun holsters are a different matter. The edge stitching isn't just holding layers together. It has to hold the shaped or unshaped product together under the stress of drawing and holstering a steel weapon. You want the strongest thread holding it together. I use #277 to hold holsters together. It is possible to bury the knots in 1/4 inch of veg-tan if you play with the top and bottom tensions. I assume you are making pancake holsters if they are only 1/4 inch thick. Most of our holsters run between 3/8 and 3/4 inch thick at the outer edge. There is a filler between the layers that positions the weapon. This filler can vary from 1/4 inch to 1/2 inch. Your Cobra Class 4 is fully capable of sewing 3/4 inch thick holsters!
Posted IMHO, by Wiz
1 hour ago, toxo said:
Well done on making the leap to a machine Phil.
Hope to see mucho productivity from here on in.
Thanks, hope your doing well, now just pulling what little hair out I have in adjusting this thing lol
It'll come. Just remember to not pull your hair out until you've got all the ducks in a row. Getting one thing right without the others being right will have you pulling your hair out. even that little spring thingy has an important job.
Yes.  I often use 277 on holsters because the LOOK of the heavier thread is popular.  But I sew a good bit of holsters (and other 'stuff') with 207.  Lots o' folk say that 207 breaks too easily, to which I say - show me ;)
That said, looking at your example I do not like HOLES that large.  This is another reason for using 277 thread, with a #24 needle ... I would prefer to use a #23 needle when sewing with 207, but for some reason #23 needles are tough to find for these machines.
5 leather patterns
I can hand sew it or carve it but this sewing machine stuff is totally alien to me, your much knowledgeable about it.
