Members Davm Posted November 12, 2021 Members Report Posted November 12, 2021 I got some light brown Fiebings but in applying- not even. If I do multiple coats each gets darker and before you know it- too dark. I have been thinking of putting a drop or two of dye in neat's-foot oil, etc. Any suggestions? Quote
Members battlemunky Posted November 12, 2021 Members Report Posted November 12, 2021 You could try NFO prior to dyeing, some folks have pretty good success doing that. Light coat of NFO, wait an hour, then dye. Some also mist their leather with water immediately before dyeing and get decent results as well. Also, the Fiebings Pro-Dye applies far more consistent; not sure which variant you are using... If all else fails and you can't get consistency, airbrushing it on seems to be the least fail method I've ever tried. I don't mind a little inconsistency though but I can totally see why people strive for completely consistent dyeing. Quote
CFM chuck123wapati Posted November 12, 2021 CFM Report Posted November 12, 2021 use an air brush. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
PastorBob Posted November 12, 2021 Report Posted November 12, 2021 I would like to air brush. Just don't have the setup for it now. I dip dye what I can. For me, it has given me the most consistent results. I use Feibing's Pro dye. It does use a lot more dye that way, and clean up can be a burger. But the results are good for me. Prior to that, I was using the wool dauber approach. For small pieces, that works fine, but the larger the leather, the more splotchy it became. Quote In God's Grace, Pastor Bob "While we were yet sinners, Christ died for us." - Romans 5:8 www.PastorBobLeather.com YouTube Channel
CFM chuck123wapati Posted November 12, 2021 CFM Report Posted November 12, 2021 7 minutes ago, PastorBob said: For small pieces, that works fine, but the larger the leather, the more splotchy it became. I found that also, now I don't fight it I either air brush or I Use a piece of natural sponge that produces a mottled/ splotchy job but it looks to be a lot more natural splotchyness. i learned the technique from water color painting. I agree dip dying is about the only other way for a nice even job. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
