DrmCa
Edge guide screw holes on a flatbed
Needing to make custom screws for my Mitsubishi. My thread gauge shows that it is 1/8-40 thread. Does anybody know if it is US60 or Whitworth thread?
You saying .."40 TPI " . . I just checked on a Mitzu. DB on the factory tapped holes on it's bed top . I threaded-in some ( 6-40 ) and they threaded in and bottomed out holding firm .
But they did feel a little tiny sloppy when I was threading them in . Cast metal Heads are kind of soft easy to drill/tap  .  So I cant tell if it just a sloppy Tap work at factory ? . .  Or it is some proprietary Thread size/pitch, that Mitsubishi used, that is real close to 6-40  ?
Thanks! 6-40 and 1/8-40 screws are virtually indistinguishable. Could be either of them. I only need to chase the threads that have some spray paint in them and to make custom thumbscrews, so need to decide which tap and die to buy.
