Members Damas Posted December 3, 2021 Members Report Posted December 3, 2021 Dear All, I recently bought that machine (in a lot with the 132k10 I mentionned in another post) and I am having a hard time with it. I have a timing problem, which I tried to solve using the great following post : https://leatherworker.net/forum/topic/62477-directions-for-timing-a-singer-45k25/ I first tried to time it by moving the needle bar, but when done, I have two issues : - The hook seem a little bit too much far on the right of the neddle to catch the thread - The needle can not achieve a full revolution with the presser foot up : it's blocked in its way down, by the presser foot I then thought I need to move the shuttle in the right position by loosening the screw where the shuttle driver attaches to the back end of the shaft but I was not able to turn the shuttle by hand, it does not move at all Last but not least, both clamp screws and shuttle driver screw are in a very bad condition (head is damaged), making them hard to loosen or tie, making the whole process even much more complicated for me ! I guess someone else before tried hard to fix the machine and baddly damaged these screws Any clue where I could find spare screws in Europe ? Thank you very much for any help and support, I would really like to have this beauty back to work Quote Mitsubishi DU-105-22 - Singer 17-30, 45K25, 132K10 - Adler 30-1- Pearson #6 - Hightex CB3200
Members jimi Posted December 3, 2021 Members Report Posted December 3, 2021 Hi Damas, Could you could post some pictures......that way we can see what is going on with your machine?? Quote
Members Damas Posted December 3, 2021 Author Members Report Posted December 3, 2021 Hello Jimi, Sure ! Here are some pictures : Lokks like I can't put more media Quote Mitsubishi DU-105-22 - Singer 17-30, 45K25, 132K10 - Adler 30-1- Pearson #6 - Hightex CB3200
Members Damas Posted December 3, 2021 Author Members Report Posted December 3, 2021 Quote Mitsubishi DU-105-22 - Singer 17-30, 45K25, 132K10 - Adler 30-1- Pearson #6 - Hightex CB3200
Members Damas Posted December 3, 2021 Author Members Report Posted December 3, 2021 The shuttle itself is damaged, I have ordered a new one. I made a video showing the issue with the presser foot up : https://photos.app.goo.gl/5SQ6Nz6mTpX5pRYU8 Quote Mitsubishi DU-105-22 - Singer 17-30, 45K25, 132K10 - Adler 30-1- Pearson #6 - Hightex CB3200
Members jimi Posted December 4, 2021 Members Report Posted December 4, 2021 (edited) Hi Damas, Very nice machine you have there....same type as the one i have here from 1950,51. I think first of all by looking at your video if you got this with a 132k machine then it is possible you have fitted one of its feet? If it is #97780, 97661 or 97784 then it is a 132k foot if it is #91038 then it is for the 45k. I say this because you do not see this foot normally fitted on the 45k machines and especially the cylinder arm ones, this was not part of the options for the 45K21. There was i think 1 hinged foot for it but it came with a knife trimmer and a flat type needle plate. This type of hinged foot is more for the flatbed series and is an option for the 45k1,5,11 etc. Did your machine come with any more feet? Edited December 4, 2021 by jimi Quote
Members shoepatcher Posted December 4, 2021 Members Report Posted December 4, 2021 (edited) The screws on the needle bar clamp are toast! I would replace them. You have a part number for them? I have acquired a bunch of 45 K parts including feet. glenn Edited December 4, 2021 by shoepatcher Quote
Members Damas Posted December 4, 2021 Author Members Report Posted December 4, 2021 @jimi Thank you very much ! She's trully a beauty indeed ! I think you are right, it came with that foot mounted on it but I noticed it was different from the one usually seen on 45k and identitical to the one that was mounted on the 132k10 ! I am curently trying to get the right foot. That was the only foot that came with the machine. But I believe I will have the same timing problem with original foot, I think my needle is going far too low @shoepatcher Yes, definitely, these screws need a replacement. Original part number for needle bar clamping screws is #158 but I believe #145, #127 or #141 could also do the trick. I am having a hard time to find them somewhere in Europe... I am still trying to figure out what part number is the shuttle driver screw, because I have no blueprint for 45k25 Quote Mitsubishi DU-105-22 - Singer 17-30, 45K25, 132K10 - Adler 30-1- Pearson #6 - Hightex CB3200
Members shoepatcher Posted December 4, 2021 Members Report Posted December 4, 2021 (edited) The #158 is 3/16 xx 28TPI screw like the #128, #145, #141. These screws are available in generic now. Originals very hard to find. I have both the parts book and the operations manual for the machine. They were part of the pack I got from a late Leatherworker contributor who passed away in early 2021. He wanted me to have this info. He restored a 45K25, 45K58, 45K69. Did a great job on the machines. His wife contacted me after he died and I got all the literature and a Claes RPX shoepatcher for money. Can you determine the part # that the screw fits in. That way I can identify the screw you need. the 45K21 had the foot on it. 45K25 was the same basic machine except that it had the roller feed on it. glenn Edited December 4, 2021 by shoepatcher Quote
Members Damas Posted December 6, 2021 Author Members Report Posted December 6, 2021 @shoepatcher When you say screws are available in generic, would you please provide a link so I could check the type of screw I have to look for here in Europe based on your link ? For the other screw, I unfortunatelly didn't succeed in finding it's part number... I hopefully found a local provider for the other parts (shuttle and foot) So I will update here when I'll get them Quote Mitsubishi DU-105-22 - Singer 17-30, 45K25, 132K10 - Adler 30-1- Pearson #6 - Hightex CB3200
