As PastorBob said . . . Mop n Glo or Resolene  . . . either one cut 50/50 with water . . . works great.
I use a small . . . cheap . . . bristle brush that I buy in box quantities from Harbor Freight . . . they're about an inch wide . . . I brush on the Resolene/water mixture . . . swirling it on the leather object . . . making a foamy looking mess to start with . . . then I brush out those foam bubbles . . .  left to right . . . right to left . . . top to bottom . . . bottom to top . . . until it is smooth and "shiny" . . .
I then let it dry . . . no heated forced drying . . . just hung up to dry . . . about 2 or 3 hours later I'll come in if it is a belt or billfold . . . or some holsters . . . I'll grab the item . . . and flex it a bit . . . as would be done in using . . .
Have never had one customer complain about cracking.
May God bless,
Dwight
PS:  I'm thinking the Lord likes you . . . that's two pastors in a row sent to give you information.
www.dwightsgunleather.com
