suncat33770 Report post Posted January 16, 2022 Hi, I need help finding how to oil the sewing hook on Pfaff 545. On page 4 of my manual, it says to oil the hook, item R, in the photo on page 5. I can't find the location R. I'll try to include a photo of my machine.... Thx Randy Webster Quote Share this post Link to post Share on other sites
cynthiab Report post Posted January 16, 2022 Could you include a photo of your page 5? I'm thinking that if it is like my Singer 111, there is a Tiny tiny little oil felt inside the edge of the bobbin case. You might have "cleaned" it out thinking it was dust/dirt like I did. Quote Share this post Link to post Share on other sites
suncat33770 Report post Posted January 16, 2022 Thx, I hope this works?? pg5.pdf Quote Share this post Link to post Share on other sites
Uwe Report post Posted January 17, 2022 (edited) There is an “R” in that photo, it points to a channel in the part that adjusts the bobbin case opener. Here’s a picture I found online. I added arrows and text. This hook looks a little different form the manual. Here’s a photo of the slot under the oil hole that supplies the race. It normally has a little piece of felt that holds a few drops of oil. Here’s a photo from a Pfaff 145 to show what that channel looks like after removing the hook. Two channels gourde oil the either the hook shaft of the bobbin case opener ring. Edited January 17, 2022 by Uwe Quote Share this post Link to post Share on other sites
suncat33770 Report post Posted January 19, 2022 Thx Mr. Uwe for your wonderful help and photos. I found the small channel with the felt oil pad. Mine felt was missing. I did not find the depression or channel you labled in the next photo. I was afraid to remove the center screw to remove the hook. I was afraid I would mess something up:) I love your photos and arrows. I added my machine photos to let you see what I have. This is just a fun machine I use to for my boat projects. It appears to have had little use and sews a lot better than I do:) Quote Share this post Link to post Share on other sites
suncat33770 Report post Posted January 20, 2022 Me again, Here is what is under the shuddle? I think I see the oil Channel but I think it is acessable once the shuttle is in place?? thanks for all the help... Quote Share this post Link to post Share on other sites
shoepatcher Report post Posted January 20, 2022 (edited) take the hook and bobbin case out and derust them with Dremel and wire brush that fits on Dremel. Check the tip of the hook for burrs. Machine will work better derusted. I mark oil areas with red paint stick. Helps when oiling machine. Clean up the buggered up screw heads as well. You got a high lift version of a 545. Great machine!!! glenn Edited January 20, 2022 by shoepatcher Quote Share this post Link to post Share on other sites
suncat33770 Report post Posted January 21, 2022 Thanks for all the Help!!! You guys are a wonderful resource!!!! Now time to sew!!!! Quote Share this post Link to post Share on other sites
