Hello all,
I have started making my own leather holsters and am quite happy with the results so far. While looking at professionally made holsters, I have noticed that even though the leather is the same thickness as the leather I use, the holster is much more rigid than my finished product. I have tried the hot water molding, and many other techniques (like adding alcohol or a drop of soap to the water), but I still cannot get my holsters as stiff as the professionals. Do they put on some kind of finish (chemical, coating, etc.) that stiffens up the finished product?
Any help would be greatly appreciated.
After moulding and drying completly, I dyed mine blue then black then applied acrylic clear, making sure leather was very dry in between coats so it sinks in real good, and the holster is very rigid stays open when wearing it in the waist band. I have read that the heavy application of dye tends to stiffen the leather and adding the clear acrylic stiffens it further. Maybe thats why some makers actually dip a holster in vats of dye and clear rather than painting it on? Hope this was a little helpful...Jordan
One thing you will notice is that the top holster makers use the very best veg tanned leather. Many of them swear by Herman Oak leather. I made my first IWB with leather I bought from Tandy; while it molded fairly well, it didn't have the stiffness needed to keep it open for reholstering. While I haven't ordered Herman Oak, I now get the best leather that I can afford from other suppliers, it makes a difference.
gunfighter48
A 45 may not expand but it will never be smaller than .45!!
NRA Member
PSLAC Member
You might try deglazing the leather. Works well on armor.
"Out of my mind.....back in 5 minutes"
Wow, thanks for all the suggestions! I will try them. One question though, can someone please explain deglazing? I have heard the term but am not sure of the definition or the process.
Thanks again for the help.
deglazing is a chemical process which strips all (or much of) the old finish to allow a new start for finishing. fiebings markets a deglazing solution that strips off old finishes. highly strong fumes. use outside! it does work, but the result is not like starting with a fresh, new piece of veg-tan. i consider it a last resort- if you gotta save it, no matter what, you may be able to with fiebings deglazier.
  • 1 month later...
Try this, it works for me.
After the holster is molded completely if that be the case, using a spray bottle with water get the whole holster fairly damp then "flash" dry it with a hair dryer. The result will be a much stiffer holster ready for oil and final finish. Also works well for knife sheaths.
Paul
Paul long-----108 Briarwood Ln. W-----Kerrville, TX--78028------830 367 5536-- pfl@cebridge.net
  • 2 weeks later...
Make yourself up a solution of 50% water and 50% acrylic finish. Dip for about 20 to 30 seconds, quickly wipe any excess solution off and hang till dry. Obviously you will want to dye the holster and buff edges beforehand. Also obvious is that making up the solution is only viable if you are doing more than just one holster and plan on making more in the future. Gets kinda rank if you don't use it and replenish it often. Angelus and Fiebings are the best choices for acrylic. Good luck!
T
http://www.miltsparks.com.
Second best is not an option
