I am having a terrible time locating a replacement air lift cylinder for my Adler 467 FA 373 / G2 HP. When cold, the foot will hardly lift to get anything under it. Does anyone have suggestions where to find this online or an actual part number?
Thank you! Josh
When I had to replace the leaking air cylinder on my Kansai special, I was not able to find the exact replacement at a reasonable price. Everyone told me that it is a custom-made product.
I ended up buying a Festo cylinder off of eBay. It was slightly different, with a different diameter thread, and I ended up turning its locking nut on a lathe, to create a step that fit the bracket. I did not have to because it would still hold tight, but I thought that since I can I would center it exactly at the same spot as the original.
Ended up paying US$17 for it, after having been quoted anywhere from $90 to $600.
This should give you the idea: https://www.google.ca/search?q=FESTO+AIR+CYLINDER+DSN-25-25-P&source=lnms&tbm=isch&sa=X&ved=2ahUKEwjdgaOH3Zb2AhWqTN8KHZVRCE8Q_AUoAnoECAIQBA&biw=1530&bih=840
Edited by DrmCa
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Three things I can think of that may cause this....first, is the presser foot shaft well lubricated? Second, is the air supply supplying the right psi pressure to start. It may be a regulator problem. Third, as a temporary fix try and get a few drops of oil into everything that moves on the air lift cylinder. On one I have I put a few drops on the rod occasionally and that seems to soak in a swell the seal enough to keep it going for a few weeks at a time. Another thing to watch for is that the switch that activates the ram is not bypassing the air and releasing it in the wrong direction.
YouTube Channel
Instagram
