When applying antique dye on belt how do you keep it from getting on the back of the belt? Or do you also dye the back?
I always dye the back of the belt the same colour as the front. Its the accepted here
I  just finished a belt last weekend. What I did was to cut the belt, tape the back, stamp, dye, resist, antique, and resist. At this point, I removed the tape, glued on the back of the belt, and finally stitched the two together.
I now have a belt with a nice looking outside, while the inside has no dye and no chance of staining my pants.
I always dye the back as well as the top. I use a sealer that doesn't allow the dye from getting onto the clothing.
HS
