In anticipation of my new machine many things race through my head. I've found the various thread to needle size charts but am still wondering if there is a 'Rule of Thumb" you stitchers use when using varying leather wights. I bought a Cobra 4 and it will do 6 oz to 7/8" of leather. I will be getting several spools, of different colors in both 207 and 277 along with #23, #24 and #25 leather point needles. Now for the question. Is there a chart or something in somebody's head that could fill in the blank?
Leather project OZ - ?????
Recommended Needle - ????
Recommended thread - ?????
Recommended SPI - ????
I understand that experimentation is the key however just looking for some guidelines to start with. For example. I want to do a project composed of a 4/5 oz top, 2/3 oz liner and another 2/3 oz pocket. So the total project is about 8 - 11 oz total. What needle/thread and SPI would you start with? Part of the project will just be the 4/5 oz top and the 2/3 oz liner. But I want to stitch it complete so the total weight will vary as I stitch along.
Thanks in advance,
Jon
Edited by Bluesman
If it ain't moving and should......WD40, If it's moving and shouldn't....Duct Tape. There you have it, now fix something
  • Replies 35
  • Created
  • Last Reply
Top Posters In This Topic
Leather Recommended Needle Recommended thread SPI - ????
Jon
That's a LOT of questions :)
I think I tend to run about one notch lighter than lots of folks when it comes to thread size. Some of that stuff is maybe better for pulling your truck outta the snow bank than for stitchin :)
So your specific project ... think i'd probably wanna use a #138 thread at about 6/7 spi. There's some 'flex' in that depending on how firm the leather is, and such. Depending on where the pocket "hits", I might use up to 8spi. I rarely do anything 'tighter" than that.
For gun slings / guitar straps, same thread and maybe step it up to 6 spi (largely decorative anyway).
heavier stuff, heavier answer - so, holsters 207, weightlifing belts 207 or 277 @ 5 spi (that much strength isn't necessary - only in the mind of the weightlifter).
I personally use thread down to a #46 (as well as 69 and 92) but that's under what your machine wants to do, no?
Edited by JLSleather
5 leather patterns
JL thanks just what I'm looking for, guidelines and opinions. yes the Cobra goes down to a 138 thread. Actually not a lot of questions just trying to put together a recipe so when I want to do something I have at least a starting point.
I try to match the size and breaking strength of the thread to the project. Plus, one has to choose a combination that conceals the lockstitch knots between the layers. So, here are some of my general recommendations for you.
  • For very thin and/or soft projects, 3 - 5 ounces: #69 thread with a #18 needle (below 441 practical limit. Round point only.) (8 /inch)
  • For thin projects, 6 - 8 ounces: #92 thread with a #19 or #20 needle (at practical bottom 441 limit. Round point only.) (7 /inch)
  • For 9 - 12 ounces: #138 thread with a #23 needle (typical, consistent 441 bottom limit. Smallest leather point 794 needle) (6 /inch)
  • For 13 - 20 ounces: #207 thread with a #24 needle (great for stitched belts, single and double leather) (5.5 /inch)
  • For 21 - 28 ounces: #277 thread with a #25 needle (5 /inch)
  • For 1/2" to 3/4": #346 thread with a #26 needle (4 /inch)
  • Extra heavily stressed projects, 3/4" to 7/8": #415 thread, with a #27 needle. (3.5 to 4 /inch)
Exceptions
  • Holsters, outside the pants, with security thumb-breaks: If at least 1/4 inch thick, use #277 thread, at 5 /inch. The knots can be buried inside the layers and the 44 pound thread breaking strength resists tearing during a struggle for the gun.
  • Sam Browne duty belts, 1/4" to 5/16" should be sewn with #277 thread, at 5 /inch.
  • Extra thick, double leather (over 3/8") professional weight lifter's belts should be double row stitched with #346 thread, at about 3.5 or 4 to the inch. These belts take a tremendous amount of stretching and abuse.
Stitches per inch
I use long enough stitches to look good on top without forming loops on the top or bottom when the project is bent (like a belt). Conversely, when the work calls for closer stitches, you have to make sure they don't perforate the stitch line.
Why?
"S" point needles, like the type 974 Schmetz makes for 441 clones, slice the leather with inline, wedge shaped cuts. This buries the ends of the thread inside the top grain and makes it appear like the stitches are closer together. If properly spaced, thick thread adds to the strength of the package. But, if placed too close, the holes in the leather weaken the package beyond the thread's ability to secure it. In fact, if the holes are so close that the thread is stronger than the leather between the holes, it can slice right through them. Also, the larger the diameter of the thread, the bigger the knots formed by the lockstitches.
When sewing with thick thread, like 207 and larger, space your stitches out to avoid slicing through the leather: e.g., no smaller than 6 to the inch. When sewing with #138 thread & 23 needle, you can go a little shorter, to 7/inch. If you use #69 or 92 thread, 8 to the inch is okay.
Thread breaking strength list
  1. #69 (T70): 11 pounds
  2. #92 (T90): ~16 pounds
  3. #138 (T135): 22 pounds
  4. #207 (T210): 32 pounds
  5. #277 (T270): 45 pounds
  6. #346 (T350): 53 pounds
  7. #415 (T400): 72 pounds
Edited by Wizcrafts
Posted IMHO, by Wiz
Thanks Wiz....excellent primer. Just what I'm looking for.
Exceptions
Stitches per inch
Why?
Wiz,
Great post and very useful info......thanks!
Wiz, that response should be a sticky..
Cya!
Bob
Cya!
Bob
I MEAN it ... Primer? That's a whole CLASS :)
5 leather patterns
Well as long as this may be a sticky. how about this. Which direction does the needle thread come off the spool? If I pull it from the back the spool turns clockwise. If pulled from the front the spool turns counter clockwise. i'm asking because I've read the comment "left" and "right" hand wrap. How does this enter into the equation. The thread I will be using is coming from Cobra.
If you are using the 1/2# or 1# spools, the thread comes vertically off the top of the spool. You will have a spool stand that holds usually 2 spools. The spools don't rotate. Take a look at the web photos of your machine or a number of videos that are out there.
Tom
