Is there a particularly good material to use for insulation?
I'm planning to make some diaperbags, and one thing everyone said when I asked about features, was insulated pockets for bottles & sippy-cups.
I think I know how to make the pocket so it's almost waterproof, but I need some insulation and am not sure what to use. I have zero background in regular cloth sewing & such like, so I have no clue what is even out there.
And the search of google and LW didn't really help (although I found a lot of bunnie-trails on LW!!!)
I'd probably start out with one of those foam pop can holders. Don't forget to insulate above, below and all sides, . . . as any temp change there can cause condensation, . . . which we all know is not good for leather products.
I'd go so far as making a waterproof shield between the product and the inside also as a JIC measure.
May God bless,
Dwight
www.dwightsgunleather.com
Lots of types and thicknesses of foam are available. Probably a good idea to use a closed cell type foam that won't become a sponge to any moisture. Outside of foam, there is quilting batting materials. Again try for a type that won't soak up moisture. Other things ... Like fiberfill, layers of wool ... Depends a lot on your construction methods. Like has been mentioned, make the pocket waterproof so any leaks are contained. You might want to use some vinyl stuff there.
CTG
As bottles and such like to leak I would put snaps and make the liner out of ripstop or material used to make raincoats. Then when it gets yucky, wet , etc., it can be pulled out and washed.
Randi-Lee
To some, I'm a dream.
To others, a nightmare.
There is a material that is like the insulating blanket NASA used in the space station. It has several thin layers and one of them is like a space blanket. My Sis-in-law used it to make waterbottle carriers. I'll try to remember to get her source for you. Remind me tomorrow.
A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Reminder :D
Reminder :D
Thanks for the reminder Dan. I've sent the email. Hopefully she will remember. In the meantime I'll try to google it.
Syl
Syl
Thanks. That sounds like the ideal stuff.
Here's a video of the stuff. I don't know how she got it... or even which layers it's from.
http://videos.howstuffworks.com/discovery/27712-how-do-they-do-it-spacesuit-insulation-video.htm
I think I found it. It's called Insul-bright
http://www.joann.com...ght/xprd986469/
Here's a better price
http://www.amazon.com/Wide-Insul-Bright-Mylar-Batting-The/dp/B001IYFCLE
She would make those water bottle cases out of this and 100 denier nylon. She would put a frozen water bottle in it in the morning and by the time she got home from work 9 hours or so later the bottle was half ice. So I think this should work well for you.
Edited by Sylvia
