tielz
Everything posted by tielz
This is a new machine with stand, motor, and speed reducer. Adler clone. Smooth running and tested on scraps. Comes with an assortment attachments. Belt guard still in original box. Purchased new with the intention of starting a small business, but never came to fruition. Kept in my home. This machine is very clean!! Located outside of Roanoke VA. $3000/obro
Removing front of panels from Lane Fox saddle
tielz replied to tielz's topic in Saddle Identification, Restoration & Repair
Thank you for the upload tips! Here is the saddle. The blue mark is where there is a stitch holding the panel to the upper leather. When pulled apart, there is a hole at the top and a hole at the bottom. There was no third hole where anything was back stitched. The tack is above the stitched part up underneath the little flap of leather at the button level. I used my curved needle to go in and out of the panel. The original was knotted at the start and finish. I am just having trouble sliding the final knot back in between the panel and leather. There has to be a technique to this. I just don't know it. I also could not tell if the knots were somehow joined together versus being two separate ones. The old stitching was a bit rotted. The tack is under the flap of leather in this area. You can see in this photo the little wad of linen thread between the panel and the leather where it is knotted. -
Thank you for your reply. I have photos, but I don't know how to upload them from this Ipad. I did get the front panels off. There is one doubled stitch holding the flap to the leather under the skirt that runs a sort of loop. Right up from that was a single tack that pulled out. The panels came off easily. I cleaned everything up and the new billets went on easily. Now I am struggling with tying the final knot after replacing the stitching. How do I pull it up close to the saddle between the tight leather? I am used to back stitching on bridle work versus knotting. -
I am usually able to replace billets without dropping panels. I have an old Cliff Barnsby Lane Fox that needs the front of the panels dropped due to the webbing being so short. There is this thread that I can snip by the front dee and a tack/nail up above that on the underside. What is the best way to get that little tack out without breaking it off? It is really flush with the leather and I don't want to damage the saddle in the process.
Is anyone familiar with the older Osborne Harness Needles? I would like to find John James that are equal or close to the size that I like the best. I have tried the new Osborne and I am not happy with them. The egg eye is smaller and it takes forever to thread the needle. The package says Egg Eye, Quantity 25, JJ, No. 3. I think that I bought these back in the late 80's or early 90s. The packs do not say gauge or length.
Thank you! I did not even think of using my dremel. I will do it this way.
I do, yes. I guess I was thinking that a sharp edge would be left, but I can always file that down.
Thank you all! Is there a certain place to cut the spring or anywhere along it's coil? High tension is an understatement! I cannot even put my finger under it at the most "loose" tension.
I am learning to use my Pfaff 331. It has the roller foot on it. The machine is the 331-33, which came with the presser foot and it's presser bar. Somewhere along the line it was changed to a 331-4 with the roller foot and presser bar that goes with it. The manual shows no difference in the springs for these different presser bars. I cannot seem to get the pressure to lighten up enough to not put tracks in the leather as it sews. I have tried unscrewing the nut on top until it is just on with the first few threads and it does not seem to make that much of a difference. If the leather is smooth, it is going to get a design in it whether it likes it or not. I cannot move the roller attachment higher up on the bar because there is a little bar stopping it. Does anyone have any ideas on how to change this? Most replacement parts are obsolete for this machine, but I have found a few select ones like the outer spring for the bar and the presser bar and components for a presser foot (but no presser foot). I have not ordered anything yet. Besides this issue, I really have no complaints. She sews a nice stitch with 69 and 92 thread.
Thank you. I will do that.
Thank you. It is local and she said that I can come and test it out. Is there anything that I should be looking at in particular to check out an older machine?
Does anyone have any information on the Pfaff 331? I can find very, very little online. Manuals are not available. There is one video of someone working on one, but they are not saying anything about the machine. I found one for sale locally and wonder if it is worth investing in for things like horse blanket repair and light leather goods. Will parts be impossible to find? Thank you in advance!
I would like to find someone who can shorten a pair of western stirrup leathers. I do not have the tools to remove and replace the existing rivets. Fenders are youth size roughout leather from a barely used saddle. Please PM if you have time to help. I am located in VA, but will ship if needed. There are no local shops. Thank you in advance.
I have two large bins with rolls of high quality leather tanned in England. Colors range from Dark Havana, newmarket, to london. Bridle, rein, and stirrup weights. These are the butt leathers of the highest quality. In these bins are also a couple sheepskins, roo-hides. There are are matching lightweight lining strips for some of the leather. I was going to be making halters. I also have the solid brass halter hardware and the stainless steel stirrup buckles. I am open to offers. There is well over 1k worth of hides and materials here. I just moved to PA, so everything is packed up in bins. If interested, please email tielz1@hotmail.com
I have already moved. The machine is in West Alexander, PA now.
Still available
The drawers and splitter do not convey. Clean and only a few hours on the machine. Open to reasonable offers. Buyer to arrange and pay shipping.
Due to my health I am selling my barely used (hobby) Cobra 4. It comes with all of the attachments (premium package) plus some extra spools of thread sizes in natural. I cannot locate the DVD or instructional book due to a move. Needs the bar and keeper for the release foot. It was lost in the first move. $2000. Located in Floyd, VA. Will be moving in Oct to PA, but would rather sell before moving. Thank you, Lori
Offering 3 Osborne stamped tools for sale. All original, no repairs or missing pieces, stored in home. No. 50 Gasket Cutter w/extra blade $75. Never used No. 34 Scratch Compass, no.1, 2, and 3 size cutters plus regular compass end $85. Lightly used No. 153 Spring Punch size 1 $65. Lightly used Will sell together for $210. I accept Paypal and will ship USPS the next business day after payment. Shipping will be exact zip to zip Priority with tracking number. Insurance will be extra. Thank you for looking, Lori
For sale: Tandy Leather 8" blade leather splitter/skiver. Adjustable arm, metal twisted handle. Blade recently professionally sharpened. I purchased this new years ago and it has always been in the house. It has sat more than been used, so only needed sharpening this one time. It has years of use left in it. Razor sharp blade that can split leather down to almost paper thin if you slip off the locking mechanism. $265. plus actual shipping from SW PA or pick up for free. I do accept Paypal. Will be packed carefully.
