educatedcobbler
Everything posted by educatedcobbler
  1. Its been couple of years I'm in here. After done my graduation in footwear engineering from Dhaka University I did job as designer in ABC Footwear Industries. I left that company. Month Later I open a workshop for myself. Started making leather jackets, belts, bags and shoes. Here is my company link named RAVEN. I'm okay and happy.
  2. Its been couples of years here in this platform with you folks. I can remember that when i opened this id I was doing my undergrad. Undergrad complete years ago and headed to accomplish postgraduate. And of course doing work with leather. Well, today i'm going share with you a event which is going to take place in Ashland, Oregon, USA in June 24-26, 2016. The event is "Footwear Symposium 2016". If you are a shoemaker or footwear professional or shoelover then a huge G2G is waiting for you in there. Like previous year 2015, this year in June 24 to 26 Footwear Symposium is going to happen. Shoemaker from different location goes there in order to exchange knowledge. Show off there work and interact with different personalities. Shoe Designer find inspiration, gather knowledge and understanding about footwear making process like construction and finishing. Shoe repair expert finds repairing material source. And Shoe Making Student/Learner meet shoe expert and learn comprehensive shoe making. Everything in a row! So why wait! You too also join there!!Website of Footwear Symposium already started registration for this year pretty soon. You could register yourself from www.footwearsymposium.com as attendant. All other related information is there regarding to the event, Guest Lecturer, Speaker or Venue, Schedule and in details. You could attend there demonstrate your art work also! So friends lets meet there!!!!
  3. leather bleach is good for cleaning any stain on leather which base form is oxalic acid
  4. dnt try that , it will damage your foot for sure
  5. use google it is best for your demanding criteria
  6. this sewing fault can happen due to ---- incorrect sewing tension (adjust the tension) ----needle incorrectly set in needle clamp ( reset the needle) ----incorrect threading ( re thread machine ) ----poorly lubricated thread ( use better quality thread ) ----feed dog sway ( tighten the feed dog ) ---- pressure foot bounce ( proper pressure foot )
  7. impressive work man , keep doing wanna learn how to make shoes??
  8. on thing for strong bond use neoprene proper way , imean dry for 10-15 min before attached parts after that u can sew
  9. first roughing up the surface then apply neoprene adhesive , of course you have to maintain allowance while rough with emery paper .
  10. well im a footwear engineer , doing all things with shoe and leather,leather goods too
  11. use pattern paper of 250/440 gm , it is best for making any kind of pattern
  12. wish i will be there next year or latter
  13. well done , try a new pair
  14. just clozed 3 pair shoe upper , have to get some sleep . gud nyt guys
  15. if u wanna make shoe by hand i mean hand making shoe then u should bye some hand toolls like beeding hammer speicial type scissors knife ladies hammer , eye lyts driller , sewing machine and all avob u need pairs of last needle specification: u may use 134 size LR cut
  16. for upper part u may use aniline or semi aniline finished leather thickness around 1.2-1.6 mm , its really depend on which types shoe u gonna made and for linning u may use vagitabble tanned leather thinkness around .5-.8mm you may follow hand book of a footwear tech.
  17. okz here im for your solution Counter: A stiff piece of material at the heel of a shoe positioned between the lining and upper that helps maintain the shape of the shoe. The counter helps strengthen the rear of the soe. Heel: The heel is the part of the sole that raises the rear of the shoe in relation to the front. The heal seat is the top of the heal that touches the upper, this is typically shaped to match the form of the upper. The part of the the heel that comes in contact with the ground is known as the the top piece. Insole: A layer of material that sits inside the shoe that creates a layer between the sole and the wearer's foot. A la The insole adds comfort for the wearer, while hiding the join between the upper. Linings: Most shoes include a lining on the inside of the shoe, around the vamp and quarter. These linings improve comfort, and can help increase the lifespan of the shoe. Outsole: The exposed part of the sole that is contact with the ground. As with all parts of the shoe, outsoles are made from a variety of materials. The properties the outsole need are: grip, durability, and water resistance Puff: a reinforcing inside the upper which gives the toe its shape and support. Similar in function to a toe cap. Quarter: The rear and sides of the upper that covers the heel that are behind the vamp. The heel section of the quarter is often strengthened with a stiffener, which helps support the rear of the foot. Some shoe designs use a continuous piece of leather for the vamp and quarter. Seat: Where the heel of the fit sits in the shoe. It normally matches the shape of the heal for comfort and support. 'Shank: A piece of metal inserted between the sole and the insole lying against the arch of the foot. Sole: The entire part of the shoe that sites below the wearers foot. As opposed to the upper. The upper and sole make up the whole of the shoe. Throat: The front of the vamp next to the toe cap. For shoes were the vamp and quarter panels are one piece the throat is at the eye-stay. Toe cap: Shoes may have a toe cap in the front upper of the shoe. Toe caps can take various forms, but the distinct types are: complete replacements for the front upper of the shoe; stitched over toecaps that add an extra layer to the upper; solid toe caps for protection, such as steel toe caps. Stitch over toe caps may be decorative in nature. Toe caps help add stength to the upper front of the shoe, an area that receives a lot of stress and wear from use. Top Piece: The part of the heel that comes in contact with the ground. Made of a durable material that helps maintain friction with the ground. Topline: The top edge of the upper Upper: The entire part of the shoe that covers the foot. Vamp: The section of upper that covers the front of the foot as far as the back as the join ot the quarter. Waist: The arch and in-step of the foot. Welt: A strip of material that joins the upper to the sole dnt forget to ask me anything about shoe
  18. hello everyone
    1. LNLeather
      LNLeather
      Hello and Welcome to a Grrreat place to read and learn about leather work.
    2. educatedcobbler
