TheLoudOne
  • Content Count
    71
Everything posted by TheLoudOne
  1. https://www.jahn-lederwaren.de/images/produkte/i20/206750227-559-opu-rucksack-03.jpg
  2. The picture is of a clutch the guy showed of a different design of Boyce's. This design is however more of a draw string bag not a backpack. A backpack has straps and a flap to keep the elements out.
  3. Thanks! Trying to get the right shading techniques down is pretty difficult. Most all of the coloring was done with spirit dyes are probably mixed up 20 different colors to come up with the shades that I did end up with.
  4. Well I went off the beaten path on my ditty bag. No offense to the designer but to me I thought it looked more like a motorcycle fork bag. So I pulled out an old classic ditty bag design to make as seeing my old bag has seen better days. I also wanted to try my hand at pictorial carving and coloring as I have never done it before. I really got to wishing that I paid more attention in my 6th grade art class. Well it was a challenge and you said we were supposed to be challenged. Hope you like it.
  5. Sorry I'm just getting back to you on this. Big Sioux is exactly right. I get the fat from around the kidneys. It's a real dense fat. I cube it up and remove any membranes possible and toss it in a slow cooker on low. Stir occasionally and let it render down until you just have oil. I skim any membrane still floating and run the rest through a sieve bag or fruit bag for pressing grapes etc to filter the rest. In a separate pot I add roughly 10% cod liver oil, 30% of neatsfoot oil to 60% tallow and toss in a handful of beeswax pellets and let it all melt down and mix well. I actually did the 2/3rds to 1/3rd tallow to neatsfoot and it was to hard to use. I have also found mixing in jars or plastic containers set in a pot of water on the stove aids in keeping things cleaner. Basically a double cooker. It's a curriers grease and anything that will be exposed to the weather I treet with this.
  6. I render beef fat and mix in neatsfoot oil and cod liver oil along with a little beeswax and let cool to a paste. I rub this in and using heat from a hair dryer melt it and rub between my hands. Supple in no time . You have to be careful with just neatsfoot oil. You can turn it to mush. Heat it also and rub between hands. It gets soft fast.
  7. I know this is an older post but this is absolutely f@&$! outstanding!
  8. I just might have to try it to find out. :-) Now thinking about it I think I would first add my old harness fat concoction to it first to soften it up.
  9. Hi, I dont have a pattern but if you have some basic woodworking tools I can tell you how I wood make one. I wood take a holler that I want to copy. Carve out a wooden form that will fit inside the form of the hat. Then cut out a ring from 3/4" plywood a little oversized that wil fit over the newly made hat block form. The inner diameter to be just big enough to accept your leather. It should be a snug fit. Soak your leather in warm water and lay over the block and press the ring over it until it bottoms out. Turn over and work out your wrinkles and let dry. Remove and cut off excess. Skiv edge. Now just make 2 outer rings. Glue back to back but not completely to inner edge. You will want to sandwich the main edge of upper hat between the 2 rim layers and stitch or lace all 3 leathers together.
  10. I use believe it or not, wall paper border. It's durable and you can roll it up.
  11. Hi Rose, nice wallet! I also used lightweight leather inside. It is so soft and stretchy I was worried about it tearing so I made a binding to stiffen and strengthen it. I also skived and folded the top leading edge.
  12. Jumped in yesterday and finished today. Only wish I had had more time to spend on it.
  13. I'm a cranking it up should be done tomorrow. Nice work everyone!
  14. I thought the 25th was the deadline? Guess I'll get cracking if I am wrong.
  15. Hi all! Unfortunately I just stumbled onto this monthly challenge and looking forward to seeing the outcome. If it's okay I would like to jump in on the next.
  16. Hey there! Hope al is well! I'm Looking for the following but may be interested in some borders also.897,902,909,917, 918, 926, 927, 933, 934, maybe be easier to tell me whatever it is that you have left and what you want. I just got your list to open but realize it is old. Regards, John
  17. Hi, I'm looking for figure carving stamps. Do you have any?
  18. I just created an album for you in my Gallery.
  19. Hi Wyoming! Thanks for responding! It has just Caraftool Co on it. I will post pictures if you can tell me how. Thanks
