dikman
Everything posted by dikman
  1. I should have known that, as my (domestic) Singer 201K does exactly that. Because my industrial Singers don't do it, it didn't occur to me that another manufacturer would still use it on bigger machines. Dohhh. Nope, no hole in the casting that I can see.
  2. Great stuff, fellas, lots of good info here. Sark9, that (lower) cylinder arm definitely appears to be identical to mine, right down to the shape of the cover plate and various screw holes. Your machine looks to be in excellent condition, btw. Eric, that's because I took the needle out to check the size and obviously put it in backwards (just to see if anyone is paying attention....). Jimi, you're right, the tension screw is missing (hadn't got that far to realize it!), but I should be able to find something suitable from my spares. Thanks for the great photos. The feed dog doesn't look as though it ever had teeth, if someone ground them off they did an awfully neat job on it! I found the serial no. this morning - 4994398. How does this relate to yours? Uwe/jimi, that Kwok Hing site looks like where I need to go. Photo of the needle bar. Does that help?
  3. I'll take a couple of photos tomorrow, jimi. A couple of things I've found so far - mine has a disengeable pulley, there is a knob on the handwheel that releases the pulley (I'm not quite sure why it would be needed, unless it's a primitive form of release if the needle jams, and it appears that it was not normally fitted) and there is no automatic thread tension release when the presser foot is lifted, mine has a small lever on the tension assembly that you flick up to release tension. That, and the fact that there is no "H" marking on it makes me think mine might be a pretty early model?
  4. I was just looking at it, and I reckon it is a compound feed. I set it to the largest stitch and turned it over by hand and the needle definitely moved back and forth along with the inner foot, and you're right about the feed dog, it oscillates back and forth in a horizontal plane. The reason I wasn't sure initially is that reading the documentation that I could find was a bit confusing, as it certainly gave the impression that it wasn't a compound feed. I'm even happier with my purchase, now that I know it's a compound feed. I've found a place in China that sells a set of "welt feet" for a reasonable price (I'm assuming that these are standard feet, but I'll have to do a bit more research first). DrmCa - or anyone with a non-binder setup - could you post a couple of photos of the needle plate/feet area, please? This will give me an idea of just what I may need to do to restore mine to that condition. Even if I have to spend a bit for the bits, I think it will be worth it, considering how little I paid for it.
  5. I posted a couple here - http://leatherworker.net/forum/index.php?showtopic=66106 Let me know if you want specific areas.
  6. Thanks Uwe, you've done well . That's exactly the model I just bought, complete with binder. Interestingly, the label plate on mine says 335-17B, second line just has L, no H to indicate foot lift.
  7. This is the machine. While discussing the possibility of getting replacement feet at my local industrial machine place, he suggested just using the existing feet and slide the binder out of the way. The previous owner said he tried that, and it did work. Looking at it, however, I reckon I need to make a new plate to replace the long one that has the binder mounted on it (pretty easy, as it's just a flat piece and aluminium should work) and I will also need a new needle plate. A bit trickier, but I should be able to work something out. It came with a Consew clutch motor, which doesn't look too old, and a quick try before I dismantled it showed that it had pretty good slow speed control (unlike the motor that came with the Singer). I figure that fitting a smaller pulley will give me adequate control without having to resort to a servo motor. Not at all bad for $250 .
  8. Very ingenious. How about a photo of the foot pedal arrangement? Curious, you know.
  9. Today I swapped over my Chinese Servo motor, with a very small pulley, to the 166. It's like a completely different machine! I can now start very slow and it will chug away at a nice relaxed pace, giving me almost complete control over it. I reckon I can get away without using a pulley reducer. It went through 1/4" of reasonably hard veg without any problems, just using the fabric needle that came with it. Now I just have to try some thread in it.
  10. Got it! Or will have when I pick it up this afternoon. . He wanted $495, I offered $200 (because I didn't really need it) and we agreed on $250. I figure that's a bargain, as all I need to do (hopefully) is replace the feet - plus I'll have an edge binder if I ever need one.
  11. Thanks, DrmCa. I'll have a word to him about it, I think. I don't really need it, but it's a nice looking little machine and if the price is right.......(I think I'm getting the collecting bug!!).
  12. A bit more searching was inconclusive. It is a walking foot, but I don't think it's a compound feed i.e. the needle only goes up and down (I think)? The reason I'm asking is that if it's usable to me I may be able to get it at a good price, as in its present form he doesn't see it selling easily and said to make him an offer. (Having just bought the other machine may help - plus he also rides a Moto-Guzzi too ).
  13. When I picked up my 211G166 today the guy showed me what else he had for sale. One was a Pfaff binding machine, which he no longer uses. Looking at it I figured it was a walking foot, but the feet looked quite peculiar to me as they were for binding. He said that he suspected this one might be hard to sell, and it was open to offers. It's a nice cylinder arm, but we were both wondering if the feet can be changed to a more conventional style and use it as a normal walking foot. Anyone know? If so, what sort of leather/needle/thread would it be good for?
  14. Picked it up today, I had to completely dismantle it all to get it in my car and then re-assemble it when I got home (which included figuring how to put castors on it so that I can move it around in my shed). I know my back is going to complain tomorrow as those clutch motors are heavy!! Came with 14 bobbins, which was a nice bonus, and runs well - but is almost uncontrollable for my needs! Once it's started I can feather it down fairly slow, but the initial start is sudden and fast. This is with a 3" pulley fitted (it came with a 4"). Tomorrow I'll swap over the servo motor from my other machine and try that, although I suspect I'll probably have to make another speed reduction pulley as well. The bonus is that I can fit the needle synchronizer adapter that came with the motor (couldn't be fitted to the other Singer). I had a quick look at the innards, everything looks lubricated but I'll spend more time on that tomorrow. I've got the service book and the parts listing, bought some needles on the way home (size 18 and 22 to start with) and figure I'm just about set to have some fun. I had a look at the 132-K6 while I was there - it's quite a beast, but I think this one will suit my needs better.
  15. New machine , new post.
  16. Unfortunately, DrmCa, you are looking at it from a Canadian perspective. Trust me, $475 (Australian) is an extremely good price for a walking foot machine, let alone a compound feed. Used prices generally start around the $900 mark - and then go up!! There are 211G166's for sale at $1800 and up. Australia is a relatively small market, compared to Canada, the US and UK and while there are lots of industrial sewers for sale, even where I am (some at pretty good prices) walkers are rare. I missed out on two because I hesitated and didn't realise how quickly they can go. What makes this one even better is that it's been maintained and serviced by a sewing machine company and has a relatively new motor fitted. As for the Seiko, it works (the mother still uses it occasionally) but the mother said it had a timing issue (and she would know, as she used it for making leather jackets for years), so I consider that a real bargain. Pity it's so far away.......
  17. I may have just found the answer to my last question, after re-reading whiz's sticky. The 211G has a compound feed, the K6 has a snap feed, so the 211G would appear to be the better choice for me.
  18. Amazing how quickly things can change. I rang the woman and said I'd take it, and then a few minutes later I was checking Gumtree (selling site) and saw 3 walking foot machines for sale here! A Mitsubishi, a Singer 132-K6 ($800) and a Singer 211G-166 ($490). A bit of searching and I thought the 211G-166 might suit me nicely. I rang the chap and he said the Mitsi had already gone and he'd had a few calls about the Singer. Quick decision time........I said I'd take it ($475). I'll pick it up tomorrow, and he said he'd keep the K6 until then and give me the choice of either one. I then rang the woman about the Seiko and she was very understanding as it just saved me a 1,000 mile round trip. I gave her the model number and suggested she re-advertise it as a walking foot (shouldn't have much trouble selling it at that price. If it was closer I'd still buy it anyway!). So, you experts, is the K6 that much better than the 211G-166? I mainly want it for belts/gunbelts and holsters, although I realise that I'll probably still have to handstitch the holsters where they are double thickness along the edge.
  19. http://www.gumtree.com.au/s-ad/thomastown/sewing-machines/seiko-industrial-leather-sewing-machine/1090045715 This is the link to the ad, shows the machine a bit better. If it's only the timing then $350 is a bargain for Australia! There is also a Juki LU-563 which is a bit closer but a lot dearer - $950. (It's going to cost me about $200 to get either one, so I have to take that into account). I'm guessing that both machines are pretty similar in their capabilities?
  20. Here's a challenge for the more knowledgeable on here - what model Seiko is this? A woman is selling it on behalf of her parents, who had a leather business and closed up. There's no model number on it (her mom said it fell off and she didn't bother putting it back) and the woman knows nothing about sewing machines. When I asked if it was a walking foot she had no idea what I was talking about, so I got her to send a couple of photos - and it is. She was asking $650, but said she has dropped it to $350 because she just found out from her mom that it has a timing problem! It sounds promising, BUT it's located interstate, so it's a 2-day return trip to get it. Decisions, decisions.......
  21. Thanks Colt, I must admit I was thinking in terms of flat surfaces. What you say makes sense, although it will obviously depend on what type of superglue it is, as I've found some are definitely better than others! Metric 20 is pretty close to 138 thread, so his needle size is pretty much what's recommended.
  22. I wouldn't have thought superglue would have much effect, as in my experience it doesn't usually like sticking to most plastics (polyester). Skin, on the other hand...... I've started burning the ends with a soldering iron, using a very fine tip. It melts it and pushes it into the hole at the same time.
  23. Update: I used it to pre-punch the holes on a belt, two layers of 4-5 oz veg and a 21 needle, all the way around the edges, and while it did it the drive belts occasionally slipped. I'm using neoprene rubber and there's too much stretch in it, so I cobbled together a rough setup using some odd v-belts that were lying around. What a difference!! It now punches through 1/4" of hard veg (same needle) at very slow speed with no trouble at all! Looks like I'm going to have to re-jig my pulley system a bit. Although thinking about it, I reckon what I really need is a smallish gearbox on the shaft of the motor. Silverback, if you order one I suggest you request the smaller pulley (just in case).
  24. I'm curious to see just what model it is. Definitely a walking foot, non-computerized and also fairly old I'm guessing.
  25. Pretty impressive, particularly the 9mm. Shows what you can do if you have lots of torque. I suspect that using a "standard" needle may have helped, as it probably slid through the leather a bit easier.
