Workinman
Everything posted by Workinman
Thank You everyone !!! I now know what to buy !!! I really appreciate your help !!
Thank you PurpleFox & TomE !! So, when I went to my local Tandy store (not super helpful) they had mainly sheepskin rugs. Would those work, or should I ask for some other type of sheepskin product ? As you can tell, I'm a newbee ?!?!
I want to make a rifle holder (?) for my daughter as a Christmas gift. I have a beautiful leather hide, but want to line the inside with sheepskin. My question is - what kind of sheepskin do I look for ? Thank You !!
Hot Foil VS Hydraulic Press for volume stamping
Workinman replied to Workinman's topic in Leather Machinery
Thanks for your comment ! Before I bought the 12 ton press I looked into buying an Arbor press. Since my images are approx. 3.5" in diameter, I felt the arbor press would be iffy. I like the mod you made to the ram on your press. You wouldn't happen to have a photo you could post ? Also, what kind of company made that mod for you (welder, fabricator, etc) ?? Thanks again ! -
Thank you, Mike. I agree. I do case my leather as it seems to leave sharper impressions that I think are visually appealing. However, that introduces another variable- moisture content ?!?!?! Frankly, if I can solve the other issues, the pressure is something I can deal with, like you said. Get an approximate pressure for each image, note it and start there when stamping that particular image. Should be close enough to not slow me down too much. To all- I do appreciate the effort and trouble you went to in giving me your advice !!! Mike -
Thank you all so much for taking the time to offer such detailed suggestions !!! I really appreciate it ! Since the die and leather piece are mobile (not fixed to the press), I think the suggestion Mike Batson offered re creating a jig. The way Mike described creating the jig will work for me because each of dies are square and can be set up using a "poster child" of each image as Mike described. As for the pressure issue, since my press is hydraulic (not pneumatic), I will look in to adding a pressure gage. If that isn't possible, I will upgrade my press to a pneumatic press- which does come with a pressure gage. A guy at the local Tandy store also suggested that I look at the dies to see if they are warped, since I am using a 12 ton press. He thought my dies might need to be a little thicker to press more evenly (just throwing this out there if case any of you encounter another another newbie like me Thanks again everyone !!!! -
Thanks Burkhardt and Mike Batson !! I probably overcomplicated this. I don't have any (current) plans for stamping with foil, so, the only point in mentioning a hot foil stamping machine was a result of a conversation I had with a friend who also dabbles in leather. My only "need" right now is to speed up the stamping process. I currently use a 12 ton Harbor Freight hydraulic press (see photo). My stamps are brass (see photo) and are made by LeatherStampMaker here in SoCal. Everything works fine, except the alignment (very tedious) and pressure (sometimes the image is too light, sometimes too deep, sometimes deeper on one side than the other, ......). If I stamp 100 pieces, I will get 8-10 that are unsaleable (not horribe). BUT, it might take me 3+ hours to stamp those 100 pieces. BTW- The magnitude of the problem is much greater than described because I have two different product lines with 8 different designs for each. So, in a typical month I might need to stamp several hundred pieces. Appreciate your suggestions !! -
I've been stamping key fobs using an 11 ton hydraulic press. With (tedious) alignment time spent on each piece, plus making sure the image is even, I can spend hours stamping 100 pieces. I hear a lot about hot stamping machines, especially relative to higher output. So, my question is, would I be better off paying for a good pneumatic hot foil stamping machine, or a good pneumatic hydraulic press ? Sorry if this is a dumb question. I'm relatively new to all this Thank you !!
I've been wet molding leather trays using a stainless steel bowl, and a Pyrex casserole dish purchased on a local junkin trip. Unfortunately, the bowl makes a tray that's too small, and the Pyrex dish is also about an inch too narrow for what I need. I'm planning to make molds out of solid wood , but am not sure what to seal the wood with ? Thanks for your suggestions !!
Thanks Tom. I'll give it a try.
Thanks Tom and Alaisiagae ! Tom, how would the lacquer affect the leather- other than the waterproofing ? Would it darken it, stiffen it, or, leave a shiny film (like Super Sheen does) ? Thanks again ! Mike
Those are awesome...at any level of skill, let alone your first solo project ! Great job !! I'm curious how your waterproofing is working ? I also make (veg tan) coasters, but noticed they begin to stain really badly after a few weeks of use. Coffee and wine seem to be really bad, but even water leaves a stain. I've experimented with; 1) Fiebings Leather Balm; 2) Tandy's Eco Flo Super Sheen; 3) Tandy's Eco Flo Top Finish; 4) Mink Oil; 5) Saddle Soap, and; 6) Dr Jackson's Oil for Leather- ALL recommended by Tandy and Fiebing. I've even experimented applying each on to dry leather, cased leather with 1 coat to as many as 4 coats. NONE work perfectly (of course, some better than others). Also, most leave a shiny film on the surface, which for my coaster designs is not desireable. I'm sure open for suggestions any one
Waterproofing test: This time a bit more scientific
Workinman replied to esantoro's topic in Leatherwork Conversation
Bummer !! Was afraid of this. Hopefully someone else might have a suggestion. Thanks Tom -
I know this post is from 2008, but, hopefully Ed will see this question and reply. First of all, great test Ed !! Very helpful. I did a much smaller test to waterproof some coasters I made, but the best product for waterproofing the leather made the coasters very stiff and shiny. How did the Sno-Seal and Aussie Wax leave the leather ? Thank you !! -
I'm mainly interested in 8-10 oz veg tanned leather dyed various shades of tan to med brown so I can see how my coaster designs will look. If you have any pictures of such leather, would you please email to mdwintz@yahoo.com ? Thanks !
I realize this topic- which I started, sorry !!- has taken a life of its own, but, just for the record, if you watch the video on the ALD web site, ""About our leather", it clearly states that their leather comes from Mexico. I'm sure that doesn't 100% close out this topoc, but, it should at least establish that ALD is not being deceptive in their advertising.
Thanks Mike. I'll be in touch. Mike
Thank you for your helpful reply. I'm actually talking to them right now about some of their leather products. Didn't even know they do custom production. Appreciate the help ! Mike Thanks for the suggestion Terry !! Mike Thanks for the suggestion Mike !! Mike
Does anyone know how I might find a company here in the US that I can get to mass produce a leather product for me ? I don't need this right now, but hope to soon.
Thank You LatigoAmigo ! So, if I am careful to burnish so I don't burn (darken) the edges, the Tokonole will go on as a clear sealer ? If so, that's exactly what I'm looking for. Thanks again, Workinman
Hello everyone. Newbie here. I'm trying to burnish the edges of a bunch of coasters I made as gifts but want to try and retain the veg tan look. I've tried water alone, which gave me the best result. I also tried pro resist; water/pro resist; gum trag; and, water/gum trag. All seem to darken the edges ? Thanks for your help.
