![](https://leatherworker.net/forum/uploads/set_resources_1/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
327fed
Content Count
527 -
Posts posted by 327fed
Not sure why all the pages of this won’t link. I copied and pasted a link from a leatherwork.net page. I have the hole pattern printed out if it’s lost. My net skills are slipping.
Vehicles with both metric and SAE fasteners, plus Torx, plus Phillips screws. Have to drag the whole shop under the car to test sizes.
As for the T shirt, they usually have the seams closer together in the back of the neck than the front. Thats the only way I can tell without putting it on wrong.
I figured it would make your lever rust.
Here is one that would be easy. Just a strip the length of the lever with holes punched and braided on. Big loop lever, standard lever, pistol vs straight grip would vary in length.
Do you not just take wide lace and wrap it it till you run out of lever?
Cheap leather which looks fine till you finish the project and dye it and a big spot in the center wont take any dye.
I mounted a piece of conduit on the speed control foot treadle to feather the clutch motor. Worked OK, but I needed that hand to guide the leather.
I have my first machine sitting in the back of my shop. It is the same model Lucy Arnaz used in the I Love Lucy episode where she sewed her sleeve into the dress she was making. Bought it for leather. Will sew one thickness, not 2.
Something that may help you out is many industrial sewing machines have a compatible table and motor. You probably can get just another sewing machine (some call it a head) and replace yours on the table and motor you already have. All you do is lift it up, remove the belt, and it pulls off. That could save on both price and shipping for your replacement machine. You may need a speed reducer if it does not have a servo motor for speed control, or replace the motor with a servo motor.
I would not care except I have some bills due. If they don't pick up today I need to go get them out of the mailbox and deliver them after the thaw. Bill payments are taking 8-10 days without weather issues lately to deliver. I ordered a jump drive from Woodcraft that should arrive soon. It has 13 years of digital Woodcraft magazine for $20. Might keep me occupied till the roads clear.
Hey Chuck,
How regularly does your US Mail run in bad weather in Wyoming? We had a 4-6 inch snow, a lot here, not much for other areas. Still cold so it can’t melt after about 6 days. Mail is not running at all. I don’t ever remember this happening, and a lot worse snows other places I’ve lived. My uncle was our mailman as a kid, had an old 72 Blazer, nothing stopped him.
Thanks. A little light for my needs I think.
Seller thinks the tag says 281-1.
I had 2 Harbor Freight air brushes. Upgraded to their tiniest paint gun. 4 oz tank maybe. Lots more adjustment and smoother. $30 or $40 seems like. So much better for dye, but I’ m used to paint guns anyway. Can twist tip to spray pattern vertical or horizontal. There are little disposable water filters, look like a tennis ball, to thread on where the gun meets the quick coupler. The gun has a metal cap with a vent in the top. Stick tape on the vent or it will drip.
https://www.harborfreight.com/adjustable-detail-spray-gun-92126.html
Well it’s $12.99 now. And hot purple.
I use 2 coats of 50-50 mop and glow and water on new stuff. Not overly shiny, does seal in odor pretty well.
A buddy gave me some ash subfloor out of his 1920’s house. I knocked the nails out of it, planed it, set it in a corner of the leather hut. Pulled it out the other day, looks just like yours. And it warped. 100 years old and warped.
I built one of the rocket stoves this month. Partly to prepare for rolling blackouts, partly because many of the utube videos on these made no sense with how fires work. Made it out of heavy 4x4 square tube and channel I had on hand. It is for sure not a backpack stove as it weighs 32 lbs. I made about 10 modifications but now it will boil water or fry bacon in 15 minutes with 2 or 3 coffee cans of very dry twigs. Not sure where you get dry twigs in an ice storm. And most of the utube features did not work in real life. The secret weapon is bacon grease and dryer lint to get the fire started.
I have been seeing all these ads over the holiday about a solo stove, open top thing, supposed to be smokeless. There is a version with a pizza slot that’s supposed to cook a pizza in 90 seconds. I don’t think a hydrogen bomb could cook a pizza in 90 seconds.
That wood tone won’t show the bloodstains like the usual maple.
I lied. These came from leatherstampmaker.com. They helped me with the design, as did some on here, as my files were not the correct thing they needed. The big stamp was about $150, 3 inch. the heater was $40 but they have bigger ones. This was 40 watt. The one inch round was $60. takes a long time to heat up the 3 inch stamp.
Moving Industrial machines around the shop and outside
in Leather Sewing Machines
Posted · Report reply
Mount them on a little trailer with a bench seat?
