Content Count
19 -
Calendar
Everything posted by JonesCoLeatherworks
Need help b/c OMTech support nonexistent
JonesCoLeatherworks replied to JonesCoLeatherworks's topic in 3D Printers and Lasers
I tried realignment again, The pics attached does not make sense that it could be dead center at position 1 and vastly so different at position 2? Bent rail?? I put a level on it and its level. -
I have an OMtech 2028 60 w C02 -Lightburn software. After replacing (upgrading) mirrors and lens, realigning beam, I get a light marking onto the material. The AMP meter shows normal output for setting but it seems the power isnt there to cut or engrave. Mind you, it was perfect up until I add the chiller. I thought maybe when moving the laser unit to access the back side of the unit to connect chillers hoses that I might have knocks something loose or broke something physically. Once I get to OMTech support the just keep asking for pictures/videos etc (which I have sent) but I get no support and I cant wait weeks to solve the problem, because I have built a business around this laser. Here are my thoughts in search of sage advice. With mirrors being new and clean, with alignment dead center, with power supply acknowledging correct output for power setting, the only thing I can think of is a bad tube? Thoughts? -
Looking for anyone with experience in laser mirrors? Problem is between mirror 2 and 3, no power. Plenty of tape burn from 1 to 2, but when I pulse nothing gets from 2-3 and the pulse is unmarkable on paper or tape. Any clues would be helpful. Will be replacing mirrors, but I have cleansed the mirrors, realigned up to 2, but not enough power from 2-3 to check alignment. Thanks in advance.
Techsew sk-4 Skiver blowing fuses
JonesCoLeatherworks replied to JonesCoLeatherworks's topic in Leather Machinery
Resolution: Had to purchase new motor. Tech support thought it could be controller board or motor. I opted to go with new motor since it would include the control board. I have been hand skiving materials in the interim and I have a deeper love for my SK-4 now. Thank you all. Great discussion -
Good idea. I have no problems with it until now. Thank you -
good info. I took a part the covers to visually inspect the bell, stone and feeder. I pulled the belt off the motor pully and it still blew the fuse. Sounds like I have a bad motor! YIKES! Nothing is binding, everything freely turns. The machine is fairly new, I could not imagine it lasting this short duration. As I try to rotate the pully, it has resistance, when I push on the foot pedal and rotate the pully, the pully moves freely. I guess I'll be making a call to Techsew tomorrow. Thanks all for steering me in the right direction. -
I see Techsew sells T 10amp 250v fuses which are "slow blow", not fast blow. Would this make a huge difference? -
It initially happened when I started sharpening the bell. Then blew. I will do a visual of the knife itself and see if it being binded up or something stuck there. Recently oiled a week ago and was working fine until sharpening. Appreciate the feedback, thank you -
It has its own. -
What's up family- I was sharpening my bell the other day when the fuse blew. Got some new fuses and every time I change it and press the foot lever, it blows another one. Any ideas or thoughts on why this is happening? Fuses are 10A 250. Troy
Thanks for the response. This was the position that timed with the hook in the scarf. After much deliberation, I went below and loosened the bolts on the shaft and somehow it fell into place. All is working now and perfectly timed. Weird how sometimes things work out. I'm not sure what I did, but it was a blessing.
Hello Friends, New issue. I swapped out an #18 needle to a #24 to load thicker thread. Even though the needles are the same length, I needed to adjust the position of the hook shaft because the hook was running into the needle. Got the hook to clear and positioned perfectly in the scarf, but now (see pics) the needle is running past the saddle and causing it to slightly bend. Does the saddle move perpendicular only or is there an up/down position as well? Stitch length set to '3'. Needle is all the way into the needle bar and needle bar is set to 5.5 cm (55mm) from needle bar rocking frame. I look forward to your responses. @Techsew Ron
From the fabulous Las Vegas, Nevada
JonesCoLeatherworks replied to JonesCoLeatherworks's topic in Member Gallery
Newly added a Techsew 2750 Pro, have a SK4. I have been mostly attracted the Bison and Horween leathers, but one of my favs is Sienna leather from Sepici tannery out of Turkey. Appreciate the welcome. -
Starting an informative series of Leatherwork Videos
JonesCoLeatherworks replied to YinTx's topic in Show Off!!
You are truly gifted. I'll refer to you with any customer requests!! -
Glock 21 45 auto/ snapping turtle holster
JonesCoLeatherworks replied to Garyak's topic in Show Off!!
A holster definitely for open carry excitement. Would hate to conceal something so beautiful. Nice work -
Just messing around with different small leather items like most folks. It started out as something to do during off time work with covid, and now has grown to be a monster buying expensive machines and whatnots. Then I started playing around with laser and acrylic and now convert leather patterns to acrylic. I enjoy learning new things and figuring out problems, especially now with a new sewing machine, and building skill sets that lead to being better at what I enjoy. Cheers!
Great advice all. Thank you for the input and resources. Yes, Ron, I was contacted by you all as well. Northmount, I did try to insert through the tab, but would not take the photo. Perhaps there a certain formats that are only allowed. I will work on that. I did get the issue fixed, but I never owning a sewing machine could be so complicated. Great to be a noobie to the sewing community.
Just got this machine Friday and it has been one problem after another. I have learned more about industrial sewing machine in the last 72 hours. Scarf/hook way off, needle bar adjustments, tension adjustments, 5 broken needles and a lot of curse words. Now this, which I can not find the answer how to fix. Called Techsew support-seems useless. Can't talk to anybody about the issue. I went through a lot of threads here, but haven't found any with my particular issue. Thanks Troy
