diylea
  • Content Count
    5
Everything posted by diylea
  1. diylea
    Cutting Dies
    LEATN MORE: https://www.diylea.com/collections/cutting-die EMAIL: support@diylea.com
  2. Strap on the side of the oil good helper, not only can hold the flat strap drum strap can also be securely clamped. Movable chuck, 360 ° rotation Product information: The strap clamp chuck is made of aluminum alloy with anodized surface. Some parts are made of stainless steel, with excellent rust resistance. The base, bracket and swivel handle are made of black walnut. Weight of strap clip: 550g Packed weight: 700g Package size (LxWxH): 23 x 13 x 16cm/9 x 5.1 x 6.3 inch Learn More:https://www.diylea.com/products/handcrafted-strap-clips Email: support@diylea.com
  3. Yes, you can click on the link to learn more about the product and purchase it. https://www.diylea.com/products/belt-quick-trimmer Any questions you can contact me. Email: support@diylea.com
  4. Not only is the cutting edge fast, but even the sanding time will also be significantly reduced, so to speak, the closer the cutting edge is cut to the desired roundness, the more it reduces the sanding time and does not require coarse sandpaper to sand the round shape. Introduction of the product 1. The overall base is made of aluminum alloy with an anodized surface 2. The steel of the cutter head is made of DC53, with hardness treatment to 59-60°. 3. Each head is equipped with 12 sides of the blade, you can replace the blade by angle, which means you can use 12 sides of the new blade, simple and convenient, no need to sharpen the blade often. 4. The net weight of the whole machine is 2.4KG, length 28.5x width 13.8x height 7.8cm About the choice of belt width and thickness 1. The width of the trimmer is adjustable, the narrowest 13mm, the widest 80mm, both shoulder belt and waist belt can be used. 2. 3 # knife head specifications for 3-4.5 mm thickness of the belt strip, which is the most conventional range of belt thickness. (default send 3 # knife head) 4# blade specifications for 4.5-6 mm and above thickness of the belt strip 2 # knife head specifications for 2-3 mm and above the thickness of the belt strip. The grinding of the edge: When we use it for a long time, all the edges are not sharp, of course, all 12 edges are blunt is also takes a long time.
