SUP
Everything posted by SUP
  1. SUP
    Some of my works
    Ditto!
  2. Aussie's is mainly petroleum jelly. It could make the flesh side sticky.
  3. Neatsfoot oil before the vinegaroon gives a matte deep black color. It can be used after as well and sometimes turns grey vinegaroon dyed leather black. . If the leather goes grey, it is either because there is insufficient iron acetate or because more tannins are needed. This is what I do. In case of the former, add some more steel wool to the vinegaroon and keep aside a day or two and try again or make a fresh batch of vinegaroon. If the latter, dip in strong black tea for a few minutes and rinse well to get rid of all the loose tea and then try with vinegaroon. In all cases, I rinse the dyed leather well after the vinegaroon and then allow it to dry. The neatsfoot oil first, prevents it from going stiff. The water rinse removes extra vinegaroon which can leave a vinegary smell. The water also balances the pH. All my Vinegaroon dyed pieces are a deep black and not dry or stiff.
  4. I have discovered that the conditioner from Chemical Guys and Resolene works. I apply the conditioner, including under the scale areas. I allow it to dry for 4-5 hours. Then I apply a layer of Resolene in the same way and allow it to dry for a day. A thin layer of Resolene though. The result is a leather that glows softly and is less vulnerable to damage. Hope this information helps anyone else who is working on Pirarucu. If anyone else has better ideas, do share.
  5. Search for 'casing solution'. on this site. You will find many recipes as well as guidance on how best to use them to get the best results.
  6. The best possible reason to get a tattoo. 🙂
  7. Yes. I always learn some new technique with his designs. His videos are excellent.
  8. That is pretty. I like the details like the difference in the shape of the edges in the area of the cabochon.
  9. True and it is a good thing that you mentioned it. Many people do have it lying around and might think of using it on leather. It is a good idea to clarify its effects, as @dikman did. if anyone reads about it here, they will know the issues they might face.
  10. I do not eve have linseed oil at home. Ever since I heard that rags used to apply it can ignite spontaneously if stored carelessly, I prefer to avoid it. The water based, non-darkening conditioners, yes. In a few months time, when I have the time I might possibly do that. I use them anyway, so might as well check their efficacy. Again, if I am able to do so.
  11. 😄 There is always more. I have not done anything about the water based conditioners that do not darken leathers.
  12. Thank you @dikman. I'm happy to know that the experiment has helped.
  13. Yes, two years now and my leathers are all fine. I will give a final report in a couple of months - no time now - and then do a yearly report, if anything changes. Thank you @fredk for all of your input. I believe that we have contributed a little bit to understanding the effects of different oils on veg tanned leather.
  14. Your designs are unusual and memorable. One does not forget them. :-)
  15. Lovely, unusual items! Do you have these available on Etsy too? I have seen something similar there. They are in my list of things to purchase and make, the trains and the dog.
  16. Frankly, anyone with a modicum of common sense knows that this is not the way to repair a worn out billet. I would not repair a worn out strap on a leather bag in this way. Not even on a cloth bag, come to think of it. And a plain running stitch! I wonder how her shoes turn out.
  17. That's true. And the eyes are the most difficult to do, especially with any expression, is it not?
  18. What a lovely, warm gesture. 🙂 The dog is so caringly done, especially the eyes. You have caught the expression beautifully.
  19. SUP
    Some of my works
    Stunning work! Your meticulous care to detail is awe inspiring!
  20. "As has been said"... One way of putting it, I guess.😄 Different suppliers using different sources of varying qualities. The oil thickening and turning liquid again I can understand. But if the oil has a rancid smell, I wonder whether it will not transfer to the leather and linger.
  21. If the oil has a rancid stench, I would not use it. Normally, neetsfoot oil as well as the compounded mix last for a long time. The compounded oil has petroleum based products added, which have an even longer shelf life. It does not smell rancid or of much of anything. So if the oil smells, there might be something else added to replace some of the neetsfoot oil, maybe another oil altogether, that is not petroleum based. It could be anything, from olive to coconut to palm oil to even linseed oil, all of which are cheaper than neetfoot oil, so could be adulterants. All would harden at cooler temperatures and cause the cloudiness. All would also turn rancid with exposure to air, unlike neetsfoot oil.
  22. Thank you for that. 🙂
  23. I need to store the deerskins that I have, as I try to determine how exactly to choose the additional deerskins I need for my next project, as no one here seems to know the exact answer to my question, asked in another thread. As I wait, I found a way to store the deerskins, that has not damaged the deerskins as yet. So I thought I would share it here for newbies in the field like me. Others might be using the same method as well, of course.. I need this way because I do not have space to hang them all up. I store my deerskins in large zip-lock bags, the ones I received clothes in, actually. I leave sufficient air inside to provide a buffer against the weight of leather placed on top and then zip it tight. The air inside prevents damage and give it air, as it were. Of course, I have not kept them in this way for long periods as of yet, but for short periods, it works. Deerskin is notorious for getting wrinkled, so this is an easy way to prevent that. You get similar large zip lock bags online as well. Come to think of it, other leathers that might crease could be stored in a similar way as well. Hope that information helps somebody.
  24. I would like to make a deerskin vest or jacket. For that I need deerskin, which I need to purchase. The thing is, I received free deerskins some time ago and used one of them to make moccasins, which I have been using daily. They get dirty and I wash them, saddle soap and a scrub and rinse under the kitchen tap, then squeeze gently and allow to dry. Then wear again. They don't shrink or wrinkle or dry out. I conditioned them once with the Chemical guy conditioner and never since then. They are soft and comfortable and going strong. They are clearly chrome-tanned, the gold color one sees so much of. I want similar deerskins for my jacket. When I look online though, all I see is that deerskin should not be washed, certainly not like I wash my moccasins, and then loads of information on how to clean buckskin and deerskin, all saying, "DON"T WASH". I got another deer-skin, also clearly chrome tanned - it is a light mocha in color, in another lot, and that does not take to water well. It does what everyone says happens - darkens, stiffens and the color change is permanent. Luckily I tried it on a small cut-out piece, so the entire thing is not damaged. So my question is, can anyone guide me on how to select deerskins that are like those of my moccasins and not the mocha one? I have been searching online and cannot find information on that. Deerskin is too expensive to do a 'trial and error'.
  25. Looks like you got your workshop sorted out. 🙂 I like that pipe rest. So practical. Plenty of other uses for that pattern too, it is so simple and versatile. Incidentally, is that a new meerschaum?
