yuma
Content Count
40 -
Calendar
Everything posted by yuma
Pdm25150...Those are made to go on your belt or in your pocket....the pics below are made for your pocket, they are in different lengths for different cases but are all 100mm/4" wide to fit in a shirt pocket.... Roger
I assume you are asking about the forms for the top half of these pouches.....I make them from what we call " Form Ply "....the centre piece which forms the pouch varies depending on how deep I need the pouch to be, the base and the top stay the same. Roger
This is a bit of an old post, so I may as well add to it while I'm here.....This is one of three small pouches for holding 22's that I made for a mates boys, they'll easily hold up to 100 rounds.... Roger
Just finished this lot, not completely happy with them but improving... Roger
Nice work....your knives ? Roger
No, I always put in a 2 or 3 mm thick, 10 to 12 mm wide welt on the outside edge. It protects the stitching from the blade and the blade from the rivets. A bit hard to see in the pics..... Roger
Finished the last two sheaths for this bloke...top one is a small of the back sheath for a camp knife, the other is a second sheath for his " Lion Killer " knife. Here are all four ready to go... Roger
Working on it Chuck, working on it ...
Just finished a couple knife sheaths for a bloke...
Cheers, all my leather is veg tanned. Roger
Thanks, I'm making some sheaths for a bloke who makes these fancy handmade knives and I was a bit concerned about the possible effect on the blades. Roger
What do you use inside a knife sheath, other than a lining, to protect the knife blade from leather...rust wise, etc?....wax, dubbin ? Roger
MW, yes, once I removed the brass base from the plastic case I knocked the primer out, ground away some of the brass to make it thinner and used a 6mm eyelet to attach to the leather and then pushed a used large rifle primer back into the hole. Roger
Western style skirt sheath for a bowie, can be worn left or right hand... Roger
A bit over 4" square and an inch deep not including belt loops... Roger
Just finished an ammo pouch for a blokes 458 Lott... Roger
I accept the praise and I welcome criticism...constructive criticism Roger
Made an ammo pouch for a mate of mine, for either 22's or air rifle slugs. First of this type of pouch I have made so there was a few mistakes....should have used a magnetic catch instead of the Sam Brown stud, wet molded the ends which was good but found that my fingernails scratched the soft leather when I was sewing..a few other things I would do differently but thats for the next one... Roger
I have a question that's a bit like hotdogs and buns...why is it that stitching punches are spaced in a metric size and stitching wheels are measured in spaces per inch ?? I cannot find a stitching wheel that matches any stitching punch.....or is it just me ?? Roger
From an Australian mob....Makers Leather Supply... Roger
Cheers, looks like I've found some ! In steel. Roger
Thanks anyway...item no longer available.... Roger
Does anyone know what these are called and where I can get some ?? Can't find anywhere in Oz that sells them !! Roger
