![](https://leatherworker.net/forum/uploads/monthly_2023_04/575463927_wizards_1977_poster_01-Copy.jpg.09dc122671761d28c30f924621555c6b.jpg)
yuma
Content Count
38 -
Calendar
Everything posted by yuma
This is a bit of an old post, so I may as well add to it while I'm here.....This is one of three small pouches for holding 22's that I made for a mates boys, they'll easily hold up to 100 rounds.... Roger
Just finished this lot, not completely happy with them but improving... Roger
Nice work....your knives ? Roger
No, I always put in a 2 or 3 mm thick, 10 to 12 mm wide welt on the outside edge. It protects the stitching from the blade and the blade from the rivets. A bit hard to see in the pics..... Roger
Finished the last two sheaths for this bloke...top one is a small of the back sheath for a camp knife, the other is a second sheath for his " Lion Killer " knife. Here are all four ready to go... Roger
Working on it Chuck, working on it ...
Just finished a couple knife sheaths for a bloke...
Cheers, all my leather is veg tanned. Roger
Thanks, I'm making some sheaths for a bloke who makes these fancy handmade knives and I was a bit concerned about the possible effect on the blades. Roger
What do you use inside a knife sheath, other than a lining, to protect the knife blade from leather...rust wise, etc?....wax, dubbin ? Roger
MW, yes, once I removed the brass base from the plastic case I knocked the primer out, ground away some of the brass to make it thinner and used a 6mm eyelet to attach to the leather and then pushed a used large rifle primer back into the hole. Roger
Western style skirt sheath for a bowie, can be worn left or right hand... Roger
A bit over 4" square and an inch deep not including belt loops... Roger
Just finished an ammo pouch for a blokes 458 Lott... Roger
I accept the praise and I welcome criticism...constructive criticism Roger
Made an ammo pouch for a mate of mine, for either 22's or air rifle slugs. First of this type of pouch I have made so there was a few mistakes....should have used a magnetic catch instead of the Sam Brown stud, wet molded the ends which was good but found that my fingernails scratched the soft leather when I was sewing..a few other things I would do differently but thats for the next one... Roger
I have a question that's a bit like hotdogs and buns...why is it that stitching punches are spaced in a metric size and stitching wheels are measured in spaces per inch ?? I cannot find a stitching wheel that matches any stitching punch.....or is it just me ?? Roger
From an Australian mob....Makers Leather Supply... Roger
Cheers, looks like I've found some ! In steel. Roger
Thanks anyway...item no longer available.... Roger
Does anyone know what these are called and where I can get some ?? Can't find anywhere in Oz that sells them !! Roger
That striped elastic that is used to under a horse to hold the saddle on.....girth strap.... Roger
...you'd be surprised how handy it is !! Roger
