Everything posted by DaleksInc
Sheath for curved knife?
DaleksInc replied to DaleksInc's topic in Gun Holsters, Rifle Slings and Knife Sheathes
How would you go about making the welt curve properly? I don't have much experience with welting. -
Recently, I found this knife for cheap at an estate sale: https://imgur.com/a/dktTmFO I would like to make a sheath for it. However, I am not sure how to do so. The designs I have seen in the past fold along a flat edge, but neither the top nor bottom edge of this knife are flat. How would I go about constructing a sheath for a knife like this?
Thanks for the advice!
I'm thinking of making my own saddle soap (both for personal use and to sell.) What are your opinions on including scents in the blend? Some recipes I have seen use scented Castile soap as the base, while others seem to avoid it.
Fancy dyes such as we have and use nowadays were very difficult (and in some cases impossible) to do properly back then. Most of the time, leather was either left undyed (darkened only by whatever oils etc. were used to condition it), dyed/antiqued with the walnut stain @dikman mentioned, or vinegarooned (the vinegar + iron method you talked about). From what I understand, it was possible to get a dark green or purple, but this was very rare and expensive, as it was done as part of the tanning process (don't quote me on this, though; I haven't researched it in depth). If you are seeking historical accuracy (which I am assuming is the case, given your mention of reenacting), I recommend just going with natural color or vinegaroon black. That said, I recommend doing some more research; I mostly do 1800s reenacting, so my Medieval knowledge is somewhat limited.
What to do with wabbit?
DaleksInc replied to DaleksInc's topic in Exotics, Reptiles, Furs and others
Good idea! Unfortunately, my lodge has been distancing itself from Native American regalia for most ceremonies, as the tribes which used to live in our area were "resettled" far enough away that we can't easily set up a good dialogue with them. -
So, back in early October, I decided it would be a great idea to make a (female) family member a purse for Christmas! Easy-peasy, right? Well, being somewhat dodo-brained at the best of moments, I decided to make the pattern from scratch instead of using a pre-existing one. When combined with the generally hectic nature of my life at the moment, naturally this meant that a project that should have been a month of evenings ballooned into a huge undertaking which I only just finished today. At least I had fun making it! One advantage of making my own pattern is that, since I made it using CAD, I have proper technical drawings, and I can easily scan in the pattern for the carving design. Do y'all think it would be worthwhile putting the pattern up for sale as a digital download? If so, are there any sites you would suggest?
- 1 reply
- veg-tan
- hand-tooled
(and 1 more)
Have a merry and blessed Christmas, everyone!
Basically what it says on the tin. I like doing leather carving, and I would like to use my own designs. However, whenever I try to (for example) a Sheridan pattern, it never seems to turn out right. Therefore, I'd like to get a good book on how to draw the designs used in various leather carving styles.
Excluding "genuine" leather, most leather watch bands I see tend to fall into one of two price ranges: $50-$80 and $150-$200, with some outliers on either side. However, when I look at pictures, it is often very difficult for me to tell the difference in terms of quality of construction. Is there something I'm missing, or is the upper price-range due to brand-name markup?
Recently, I acquired a shearling and a couple rabbit furs (both were pretty deeply on sale). After some thinking, I've decided I want to make myself an ushanka (known as a trapper's hat in the USA.) Are there any tips/suggestions I should keep in mind?
When I use rivets and burrs in my projects, I tend to hammer the shanks down flush with the burr using a big ol' ball-and-peen hammer a relative acquired while working on the railroad. However, when I see rivets and burrs used in other people's projects, they usually seem to have barely domed the tip. Therefore, I am interested to hear y'all's thoughts on how much to hammer shanks.
Is 4-5 oz. appropriate?
- 3 replies
- chrome-tan
- pull-up leather
(and 1 more)
Yesterday, I went over to Tandy to pick up some hardware and a side of veg-tan while it's on sale. As sometimes happens, one thing led to another, and I ended up also getting a dark-brown "Utility Crazy Pull Up Buffalo Side" since it was heavily discounted and my sister commented that the feel is similar to that of a dog collar she's been wanting me to replicate. Since a whole side is (hopefully ) much more than I need for one or two dog collars, does anybody have suggestions for projects I could make using it? My experience with aniline and chrome-tanned leather is rather limited, since I usually work with veg-tan. While I'm at it, is there anything I need to watch out for when working with this hide?
- 3 replies
- chrome-tan
- pull-up leather
(and 1 more)
Look into Civil War cap boxes and pistol boxes. That said, you probably won't need a pattern; they're essentially just a basic belt-mounted box with a flap lid. The main difference is the addition of either a second, smaller flap or a piece of shearling (in some cap boxes) to keep the contents from spilling. If you have FreeCAD, I have a pattern I can send you; it's for a belt-mounted glasses case, but the design is similar to that of a pistol (just using saddle-stitched gussets instead of box-stitch.) You'd just need to add something to prevent the shot from spilling as you run around.
I just picked up a couple of rabbit pelts for cheap (my local Scout camp's trading post had them for whatever reason, and was doing a blow-out sale.) How do you suggest I use them (and/or how do people typically use them)? I generally do figure carving, so I've never used furs before. For reference, I've attached a picture of the pelts.
Are rivets sufficient for light-duty belt loops?
DaleksInc replied to DaleksInc's topic in Leatherwork Conversation
Unfortunately, I don't have space (again, it's a glasses case.) Would stitching around the rivets help? I see it a lot in American Civil War-era leather goods such as cartridge boxes. Edit: for reference, here's the body and flap of the case. Not the best picture, but it should give a good idea of what I'm working with. -
Thanks! Unfortunately, I've already cut, dyed, and varnished everything, so I'll probably have to just leave it on the outside for now. I'll keep that in mind in the future, though! -
Skiving. I can never seem to get a consistent depth.
Thanks! I'll try this. Ironically, I was just at Harbor Freight yesterday.
For whatever reason, I always have horrible luck when skiving projects. The skiver seems to occasionally "catch," resulting in severe gouging. I suspect this may be due to my skiver (a Tandy SuperSkiver.) Would a well-stropped woodworking plane produce a more even skive?
Per the title, I'm interested in using some (mid-sized) embossing plates, but don't have a clicker (and probably won't for a while; those things are somewhat expensive.) Is it possible to use an embossing plate without one, or am I out of luck?
