Members chriscraft Posted March 13, 2022 Members Report Posted March 13, 2022 I’ve been using this homemade stamp for a couple years now. I have to say that it’s the best thing I’ve ran across since I started tooling leather. I read about how to make these polyform stamps on another site and would like to share here. First, I’m a stickler when it comes to tooling leather by hand and try to use the best tools I can afford. At first, I contemplated over having a stamp made for me since the end product wasn’t going to be made (tooled) by me. I’m not a purist when it comes to calling my stuff “hand made” since I use a sewing machine anyway. But by building my own stamp, this made it feel like it’s coming from my personal skills which lead me to continue on this short journey on making my own stamp mold. First,, I hand tooled my original leather mold that will be used to produce my polyformed stamp. Once dried it was used to press on the sculpy polyform clay to transfer my form. I made it 1/4” thick and baked it at 275 degrees in my kitchen oven for 30 minutes. Then removed it from the oven and dipped it in cold water to quickly cool it down. Not sure if my cooling process helps harden it more but I think it helps make it stiffer. I used my scroll saw to remove excess material and used an antique book binding press to stamp this onto 5oz. Leather. The stamp impression results are remarkable, looks like it was all done by hand but in only 5 seconds. Amazing Quote
Members chriscraft Posted March 13, 2022 Author Members Report Posted March 13, 2022 (edited) I then stamp in the personal badge numbers and name using a 1/4” aluminum guide line. Edited March 13, 2022 by chriscraft Quote
Members chriscraft Posted March 13, 2022 Author Members Report Posted March 13, 2022 Then it’s just dye, glue, stitch, paint and finish Quote
Members chriscraft Posted March 13, 2022 Author Members Report Posted March 13, 2022 and that’s how I’ve been building these. I use HO 5oz. and end up with a good looking product that I’m proud of. Quote
Contributing Member fredk Posted March 13, 2022 Contributing Member Report Posted March 13, 2022 Thats excellent I also use FIMO/Sculpey, but for the occasional small stamp We need to edumacate the heathens on here about polymer clay, Quote
Members chriscraft Posted March 13, 2022 Author Members Report Posted March 13, 2022 2 hours ago, fredk said: I also use FIMO/Sculpey, but for the occasional small stamp We need to edumacate the heathens on here about polymer clay, yes FIMO works the same. I bought what was on sale. You can make the stamps thicker, I made some 1/2” and had to Just bake a small sample first to ensure it came out good. Not enough time in the oven and it will be rubbery. Makes the scroll saw cuts melt and bond back together. I found that baking it a bit longer then quenching it in cool water hardens it a bit. Makes the scroll saw cuts cleaner like you are sawing threw hard plastic and won’t melt/bond back while sawing. I forgot to mention that I’m pressing the polymer clay flat onto 1/4” plate aluminum. The clay stays attached to my flat plate even when pressing it on my leather form. Even when lifting it away from the leather form, the clay stays flat and attached to my aluminum plate. Then my plate goes in the oven with the polymer clay attached. Once baked, a thin putty knife easily removes it off the aluminum plate. Quote
Members SaintJoy18 Posted March 16, 2022 Members Report Posted March 16, 2022 That is a fantastic process! I'd love to see an instruction video on this. Quote
Members PastorBob Posted March 16, 2022 Members Report Posted March 16, 2022 Another one to add to the to-do list. Some impressive results. Thanks for sharing! Quote
Members chriscraft Posted March 16, 2022 Author Members Report Posted March 16, 2022 These stamps I made are big, about 3 3/4” by 5 inches and you’ll need a lot of pressure to make the impression. If you are making small stamps (about 1/2” square) then you don’t need that much force to apply the impression. My antique book binding press is heavy, about 70 pounds and large with a working surface of 15”x20”. I have seen some of the hydraulic press setups ppl use to click patters, those would work. As long as you have two (top and bottom) flat surfaces that can be pressed down evenly. the key is to keep your tooled leather pattern that will be copied nice and flat. I glued my pattern onto a piece of 6”x6” 1/4” hardboard. I place my polymer clay that’s attached to the 1/4” aluminum plate on the bottom surface of my press. The tooled leather pattern goes on top the clay and will be sandwiched down by my tooled pattern making my polymer clay mold. Then remove the top tooled leather pattern from the clay. Your clay won’t come off the aluminum plate as it’s somehow suctioned there by the soft playable clay. This process of making the large polymer stamp isn’t too difficult and if you make a mistake by the clay coming out uneven, just start over again. Quote
Members chriscraft Posted March 16, 2022 Author Members Report Posted March 16, 2022 My first 10 leather covers were all hand tooled one by one. I don’t sell many of these to really justify having a stamp but decided to make my own in case someone ordered another leather cover. I’m glad I made these stamps cause I’ve used them on about 40 different covers now. Every once in a while someone inquires about making them one and it doesn’t take me too long to build one. Quote
Contributing Member Samalan Posted March 24, 2022 Contributing Member Report Posted March 24, 2022 Wow that looks great everyone will want one now! Quote
Members chriscraft Posted March 27, 2022 Author Members Report Posted March 27, 2022 On 3/24/2022 at 6:40 AM, Samalan said: Wow that looks great everyone will want one now! You would think but one issue is that you can find a basic black leather memo book cover for $20 at any police supply shop. I can’t complete with that and I really don’t think that I am or even in the same class. I’m offering a custom made to order product that is constructed from the best materials I can find. I want it to last your entire carrier and many more. I don’t sell many of these, mostly word of mouth, and that’s just fine as this is just a hobby. I just wanted to share what I’ve learned. This site has taught me a lot and it’s my way of returning the favor. If my process helps out someone here. That’s great! Quote
Contributing Member fredk Posted March 27, 2022 Contributing Member Report Posted March 27, 2022 Thanks for the explanation on how you make the stamp(s) Do you use a release agent, such as talc, between the polymer clay and the leather? Quote
Members Mulesaw Posted March 28, 2022 Members Report Posted March 28, 2022 Looks really good, thanks for sharing the tip. I even think I have an old book binder press stashed away in a corner. :-) Quote
Members Spyros Posted March 28, 2022 Members Report Posted March 28, 2022 (edited) It's excellent, well done (also I'm a big Bucks/Giannis fan, from a distance though, you're lucky to be in MKE) Edited March 28, 2022 by Spyros Quote
Members chriscraft Posted March 28, 2022 Author Members Report Posted March 28, 2022 3 hours ago, Spyros said: It's excellent, well done (also I'm a big Bucks/Giannis fan, from a distance though, you're lucky to be in MKE) Yes I’m lucky. I wasn’t a Bucks fan till I took a Paramedic Job at the Bradley Center where the Bucks play. Job was transporting fans out of the center that needed medical assistance. I was promoted to tending the talent (All NBA players) before, during and after games. That’s when I met Giannis and found out who he was. He is very humble and just an amazing person to be around. Listening to him having conversations and interacting with his brother or teammates, You would never think he was someone famous. My first few games sitting courtside alongside the player entrance/exit tunnel, I was Star Struck. It’s the same entrance that all the VIP’s use too. Soon after I became accustomed to this. Then they built the new stadium, Fiserv Forum, the house that Giannis built. I worked there alongside the NBA players till February 2021. We were never allowed to take any photos or obtain autographs. Before my last day, Giannis signed my Paramedic patch, I’ve since removed it from my uniform and it’s now something I can stuff inside an old shoebox with other memorable items. Quote
Members chriscraft Posted March 28, 2022 Author Members Report Posted March 28, 2022 (edited) 19 hours ago, fredk said: Thanks for the explanation on how you make the stamp(s) Do you use a release agent, such as talc, between the polymer clay and the leather? You know fredk, I hadn’t thought about using anything like that. I did not use anything. Along my swivel cuts where the clay squeezes in, it just gets jammed in there and breaks off when I pull the clay away. Had I used talc or something like that I’m sure it would still squeeze in there. Edited March 28, 2022 by chriscraft Quote
Members cryptid Posted April 1, 2022 Members Report Posted April 1, 2022 On 3/13/2022 at 1:59 PM, chriscraft said: First,, I hand tooled my original leather mold that will be used to produce my polyformed stamp. Once dried it was used to press on the sculpy polyform clay to transfer my form. I made it 1/4” thick and baked it at 275 degrees in my kitchen oven for 30 minutes. Then removed it from the oven and dipped it in cold water to quickly cool it down. Not sure if my cooling process helps harden it more but I think it helps make it stiffer. I used my scroll saw to remove excess material and used an antique book binding press to stamp this onto 5oz. Leather. The stamp impression results are remarkable, looks like it was all done by hand but in only 5 seconds. Amazing This is reproduction gold! Thank you for sharing. I need to create a makers mark and this sounds like a great way to keep costs down for now. Pretty sure I have some modeling clay around here somewhere.... Quote
