Members suzelle Posted May 7, 2022 Members Report Posted May 7, 2022 39 minutes ago, Woehlk said: Got it to work, thanks for your help :D Yay!!!!!!! Quote
Members Woehlk Posted May 8, 2022 Author Members Report Posted May 8, 2022 I startet centering the needle But this screw is so stock!, I will try using a screwdriver with hammer funktion later, maybe this can loosing it Quote
Members Constabulary Posted May 8, 2022 Members Report Posted May 8, 2022 apply heat with a gas blow torch Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Woehlk Posted May 8, 2022 Author Members Report Posted May 8, 2022 10 minutes ago, Constabulary said: apply heat with a gas blow torch Wow that actually worked!! Thanks!!! Quote
Members Woehlk Posted May 8, 2022 Author Members Report Posted May 8, 2022 Its like im going in circles a bit When I adjust one thing, and get it perfect, another seem to get out if sync Could someone coach me over video? I would gladly pay for you help <3 Quote
Members Woehlk Posted May 12, 2022 Author Members Report Posted May 12, 2022 Im getting closer :D its doing something now :D Quote
Members suzelle Posted May 12, 2022 Members Report Posted May 12, 2022 4 hours ago, Woehlk said: Im getting closer :D its doing something now :D Exciting Stuff! So great to see all your work as you go! Keep it coming! Quote
Members TheMortgageGuy Posted May 19, 2022 Members Report Posted May 19, 2022 On 5/12/2022 at 9:30 AM, suzelle said: Exciting Stuff! So great to see all your work as you go! Keep it coming! question.. where did you get your presser feet? are the ones for this machine the same as the Pfaff 335 H3 and newer Pfaff 335? Quote Juki Lu563 with Servo, Singer 20U with Enduro SM 645B, Pfaff 142-6/2. BL, PFAFF 335-H3-6/01-900/52-BLN
Members shoepatcher Posted May 20, 2022 Members Report Posted May 20, 2022 Feet are not equalized as to the walk. Put the foot walk on medium lift in the back of machine. Should be a wing nut and slot on it. Loosen the two screws on top and the far left on top of the shaft. That should drop the center foot all the way to throat plate. By hand , turn the balance wheel towards you until the needle is just entering the feed dog which should be even with the throat plate. Tighten the 2 screws on top. Check lift of inner foot and then lift of out foot. Should be close to equal now for each foot. glenn Quote
Members Woehlk Posted November 3, 2022 Author Members Report Posted November 3, 2022 Hi guys!; Had to take a break from the machine, Had to work a lot, and also had a vacation, im like 95% done I think. But this problem, I need your help again. Youtube video Quote
