Members Constabulary Posted April 28, 2022 Author Members Report Posted April 28, 2022 Just in case - this was the "inspiring video". I just pulled the wire to the right for having a tighter coil Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
kgg Posted April 28, 2022 Report Posted April 28, 2022 On 4/24/2022 at 10:37 AM, Constabulary said: Saving some old cast iron again.. That is good to be a nice machine when your finished doing the restoration. Always nice to see the old iron running again. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Constabulary Posted April 28, 2022 Author Members Report Posted April 28, 2022 17 minutes ago, kgg said: Always nice to see the old iron running again. Thats what I always say Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Constabulary Posted May 1, 2022 Author Members Report Posted May 1, 2022 Small update: Upgraded the badly bubba`ed bobbin winder (proper thumb nut replaced the drawer knob, eccentric finished and bobbin holder axle replaced - still have to attach the wire) Also Finished the face plate - tension units needed several OEM parts. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Constabulary Posted May 2, 2022 Author Members Report Posted May 2, 2022 11 hours ago, Constabulary said: still have to attach the wire wire -> tire it is Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Damas Posted May 4, 2022 Members Report Posted May 4, 2022 Dear @Constabulary this post is so interesting ! it’ll be great if you could do, one day, a step by step tutorial to unmount and remount a 45k. Unless such thing already exists ? I fear to do it by myself, I am so scared I will never be able to reassemble it… By the way, I have to post about my mistery 45k mill machine (darning) : it has a feed mechanism and a stitch lenght adjuster even if there is actually no feed dog. The serial is not a Singer one, neither the plate. But parts are definitely Simanco I think it might interest you and probably @Jimmy too Quote Mitsubishi DU-105-22 - Singer 17-30, 45K25, 132K10 - Adler 30-1- Pearson #6 - Hightex CB3200 and CB243
Members Constabulary Posted May 4, 2022 Author Members Report Posted May 4, 2022 I´m not the big tutorial to be honest guy. I even forgot to take pictures of the cleaned parts cause I do this and that then and now... and when I´m in work (dirty fingers) mode I seldom grab the camera. I have it assembled already - almost. But the 45K is so simple you almost cant do anything wrong when you have some mechanics experience. Some screws are critical cause they are bit hard to reach and you need the right blade screw drivers otherwise you may damage the slits. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members shoepatcher Posted May 4, 2022 Members Report Posted May 4, 2022 C, Nice job so far!! glenn Quote
Members suzelle Posted May 5, 2022 Members Report Posted May 5, 2022 On 4/28/2022 at 12:11 PM, Constabulary said: Just in case - this was the "inspiring video". I just pulled the wire to the right for having a tighter coil Wow! You are AMAZING!!! Very interesting indeed. Thanks for sharing. Quote
Members shoepatcher Posted May 5, 2022 Members Report Posted May 5, 2022 C, Great job so far.!! glenn Quote
