Contributing Member fredk Posted April 25, 2022 Contributing Member Report Posted April 25, 2022 Have you got access to a home kitchen blender? Chop up a big onion*, put in the blender with some warm, nearly hot, water, not a little amount, about 1 pint. Blend until you have a watery onion mush. Pour this through a strainer. Mix the resulting onion water into about 2 gallons of clean warm water. Dip a big sponge into the bucket, wring it out but leave it fairly wet. Wash this over the hide. 2 gals should do several hides *More onions = stronger solution Quote Al speling misteaks aer all mi own werk..
Members JayEhl Posted April 25, 2022 Author Members Report Posted April 25, 2022 1 hour ago, fredk said: ......kitchen blender? ..with some warm, nearly hot, water, not a little amount, about 1 pint. Blend until you have a watery onion mush ahhh,,.... that's why I asked! Wouldn't have thought to use a blender to make a mush. Quote
CFM Frodo Posted April 26, 2022 CFM Report Posted April 26, 2022 No need to cut the leather up Go to home depot or wally world and buy a 4foot long plastic storage tote $35.00 55 gallon tote Interior dimensions (at bottom of tote) 39 in. L x 14.75 in. W x 17.25 in. H Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Members Handstitched Posted April 26, 2022 Members Report Posted April 26, 2022 20 hours ago, fredk said: No, the smell will still be on the items @JayEhl I had another, perhaps 'ye olde' method of removing smells. Bi Carbonate of Soda. It was once used inside fridges to get rid of unpleasant smells, like mold, musty smells from left overs etc. I'm not suggesting put the leather inside the fridge, but perhaps inside a sealable 20-40ltr tub with some bi carb. It may take a while, but it might just work . We used it inside cupboards to freshen them up . A bit of bi carb and lemon juice ( or for the Aussies) some eucalyptus oil in the bi carb. Makes a change from moth balls. HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members JayEhl Posted April 26, 2022 Author Members Report Posted April 26, 2022 Man you guys are awesome! Thank you for all the great ideas. I bought two buckets of damprid to help with moisture in the garage which is my biggest issue. Not sure if it's available everywhere but for anyone that may be curious: https://damprid.com/ Next thing I'm going to try is the onion wash thing and then cut into larger sections to place these with onions in totes, this evening. I've got a couple empty ones but will need to hop to the store to get a couple larger ones @Frodo spoke of. I'll have to report back, but will take a couple of weeks, I should think. Quote
