20 minutes ago, alpha2 said:
You're going to need some of these!
I made them for my Browning B92 and Marlin 39A Original Golden.
I have one that I ordered and it's a great little accessory. The front of the lever wrap also makes a nice indexing spot for my trigger finger.
Thanks for the replies so far. I did a supply run, purchased some belly, and got started on my first-ever attempt at a project, pictured below.
The material seems pretty thick and inflexible. Should my next step be some kind of wet molding to get a more precise fit to the stock?
Edited by Iceflags
Looks a little long. Stamp it, punch it, put your loops, grommets, dye it, wet mold last if needed. For the straight grip stock you may need a strap around the back to keep it from slipping forward.
Edited by 327fed
I does look a little thick, I usually use 5-6 ounce on mine and they get beat up pretty good at CAS matches.  Are you going to line it?
One big problem can be the sun bleaching the rest of the woodwork whilst the wood under the sleeve remains dark. Maybe not a great deal on rifles but shotguns tend to have nice walnut but the good side is they are not often out of their sleeves
Mi omputer is ot ood at speeling , it's not me
The stock cover is on hold for now, but I managed to kludge some loops together, so I'll consider this a successful introduction thread.
Looks good! :rockon:   It would probably been easier to do your edging and burnishing before.  I do like your choice of words, “kludge” isn’t something you hear everyday, I like it.
