Members NickPol Posted July 5, 2022 Members Report Posted July 5, 2022 I am looking at industrial high post beds and came across this Juki Model. The thread size in the manual states #30 ~ #8 (Japanese yarn count), needle size Schmetz 134-35(R). Is there a comparison for this thread size to Tex? I tried looking a conversion chart up but have been unable to find anything that says Japanese yarn count. I feel like I am missing something here and the answer is right in front of my face. Any help is appreciated. We typically use a T135 thread. Thanks again. Quote
Moderator Wizcrafts Posted July 6, 2022 Moderator Report Posted July 6, 2022 The Cotton Yarn numbers of #30 ~ #8 roughly correspond to bonded Tex sizes 70 through 210. Due to the totally different materials used, the sizes don't translate as accurately as measurements for cotton, or polyester, or rayon thread. There is a thread size comparison chart that includes cotton yarn equivalents on A&E Thread. There is no cotton yarn number comparison within the bonded nylon and bonded polyester groups. My best guess it that your T135 thread would be about the same diameter as #12/3 cotton. But, cotton is much lighter than nylon. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
kgg Posted July 6, 2022 Report Posted July 6, 2022 (edited) 14 hours ago, NickPol said: I tried looking a conversion chart up but have been unable to find anything that says Japanese yarn count. Thread Sizing standards can drive you down the rabbit hole that is for sure. For the less commonly used thread sizing the easiest way to determine what the machine can handle is by the range of needle sizes a machine can accommodate and from there work backwards. A rule of thumb with Juki specifications is their machines are able to handle sewing thread of the same size in both the bobbin and the needle for sewing thick materials less one thread size of the max needle size. The needle specification for the Juki PLC 1690 is for a SCHMETZ 134×35R Nm100~Nm140 (Standard Nm120) with a 120 (#19) needle recommended and probably supplied. I used the spec from the Juki site for this machine ( www.juki.co.jp/industrial_e/products_e/lether_e/postbed_e/detail.php?cd=PLC-1690_PLC-1691_E). That relates to a needle range of a #16 to a # 22 needle so from that I conclude it will sew thick materials using V46 (T45) to V92 (T90) thread. For thinner materials the range would be V69 (T70) to V138 (T135). With it's sweet spot thread being V92 (T90). I guess it will depend on the toughness and thickness of what you want to sew. kgg Edited July 6, 2022 by kgg spelling Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
ljk Posted July 6, 2022 Report Posted July 6, 2022 In my beginning years as a upholster we used cotton thread the size was 16-4 (about tex 105) and 24-3(about size 69) things were rapidly changing to nylon thread, staple guns vs spitting tacks. Most machines where 155 and 16-188. Quote
