Members Barron Posted July 8, 2022 Members Report Posted July 8, 2022 (edited) Hello! I do gold prospecting / panning recreationally and often end up with my hands rather full. My truck just cannot go everywhere I wish. (Dang rivers!) So, I was searching online for a good ruck sack that can fit a 5 gallon bucket and a sluice on the inside, and then on the outside have like 3 large pockets to put misc stuff, and of course a spot for my gold pans! (I can also throw some of that into the bucket with a few other things but would prefer it on the outside, for the vibe). However, none appear to exist. I've seen pictures of ice fishing backpacks that can carry just a bucket, or modified backpacks that can carry pans and some tools. But nothing that really keeps my hands free at all times so I can climb / maneuver if needed, and the last thing I want is to have to pick between dropping my bucket I'm holding full of misc tools or fall on my toosh or worse! Here are a few links to better show what I have/plan on putting in it. https://www.homedepot.com/p/The-Home-Depot-5-Gal-Homer-Bucket-05GLHD2/100087613 (Bucket 14" x 13") (Inside) https://www.amazon.com/Sluice-Fox-Folding-Aluminum-Panning/dp/B09CX31NFQ/ (sluice, 4.25"x 9.25" x 15") (Inside) https://www.amazon.com/dp/0671244175 (Rock identification book, 4.5" x 1.1" x 7.5") (Inside pocket) https://garrett.com/sport/pro-pointer/pro-pointer-at (Garret carrot, 9.5" x 2.5") (Outside individual pocket) https://www.amazon.com/uvBeast-NEW-Black-Light-Flashlight/dp/B07TQKY1GC/ (UV Flashlight 9.5" x 2.5") (Outside individual pocket) https://www.amazon.com/dp/B074KN9X8F (Snuffer bottle 5" x 2" x 2") (Outside individual pocket) https://www.amazon.com/dp/B06XTY8DH7 (Gold Pan, 14" Diameter) (Outside attachment / pocket with #8) https://www.amazon.com/dp/B0089OKEUK (1/2 Classifier, 19" x 14") (Outside attachment / pocket with #7) https://www.amazon.com/dp/B0002OVCMO (Rock hammer, 13" x 7" x 1.25") (Outside loop, vertical) https://www.homedepot.com/p/Anvil-28-in-D-Grip-Short-Wood-Handle-Steel-Digging-Shovel-77470-938/314833737 (Shovel, 40.39" L x 8.19" W x 5.12 H) (Outside Loop, horizontal placement on top?) Those are the main items that require space / individual pockets. Other items could be put into a few large pockets on the outside (pocket on each side + back), probably two pockets on the side and one larger pocket on the back should do it. Kind of like the images I uploaded but a mix breed between them. I believe leather would make it the most durable over a cloth or a canvas bag, but do not mind some conglomerate between where reasonable. Let me know what you think and if the reason they're just not done is because it would be dumb! Thanks! (Oh and I'm sure giving a price quote would be unreasonable as you probably can't tell time + material costs but if you think you can give a rough idea on what I should set aside I'd appreciate it!) Email: As shown on my profile. Edited July 8, 2022 by Barron Adding contact.
Moderator Wizcrafts Posted July 8, 2022 Moderator Report Posted July 8, 2022 I suggest that you buy a backpack that comes close to your requirements, then take it to a leathercrafter or upholsterer who can disassemble it, cover the most important areas with upholstery or thin chap leather, then sew it back together. Additional compartments could be added before reassembly. The leather and labor will probably come close to the price of the backpack if done by a professional. When customers ask me to do this kind of work I've learned to say NO. Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
CFM chuck123wapati Posted July 9, 2022 CFM Report Posted July 9, 2022 i used to use an older (70S era) back pack frame it had a metal bar on the bottom that folded down to support a sleeping bag i would tie on my sluice box first then load it up inside with odds and ends then. use the straps across the sluice box to tie on my bucket and anything that didn't fit in the sluice box. I also was thinking of a design similar to a ww1 model 1910 haversack which you could adapt to an external frame, their design makes them well suited for many different loads but they are small. you would need to design a larger size and i would suggest heavy canvas over leather as it is lighter and dries easier. Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members Sheilajeanne Posted July 9, 2022 Members Report Posted July 9, 2022 (edited) That third packsack is almost exactly what we used to use for canoeing during the 1970's! The only difference is it lacks the tumpline and the extra long straps, which could be adjusted to take bigger loads, then cinched tight as the trip went on and you ate your food. The top of the pack would be rolled down, and the leather straps still fastened tight as they had lots of holes in them. I am sure similar packs are still available, though now they would likely be made of ripstop nylon. Edited July 9, 2022 by Sheilajeanne
Members Barron Posted July 9, 2022 Author Members Report Posted July 9, 2022 1 hour ago, Sheilajeanne said: That third packsack is almost exactly what we used to use for canoeing during the 1970's! The only difference is it lacks the tumpline and the extra long straps, which could be adjusted to take bigger loads, then cinched tight as the trip went on and you ate your food. The top of the pack would be rolled down, and the leather straps still fastened tight as they had lots of holes in them. I am sure similar packs are still available, though now they would likely be made of ripstop nylon. Yeah, I've seen a few that are some what close to what I need but the largest ones are just slightly small to fit what I need and don't have pockets, like giant hobo bags essentially. I, for the life of me, cannot find a large enough ruck sack made from leather. The largest are always cloth or cloth with canvas or leather bottoms. Really want something durable. Going to head to a place in Oregon later this week when I get out on the river and see what I can find at a leatherworker there.
Members Sheilajeanne Posted July 10, 2022 Members Report Posted July 10, 2022 (edited) The ones we used had plenty of pockets - most important being a transparent map pocket to keep your map from getting wet while paddling! But yeah, only the bottom and straps were leather. I really can't see anyone being able to do this without having the things you are planning to put in the pack available to them. The chances of messing up the measurements are just too high. I like Wiz's idea of buying something that comes close to your requirements, then having a leatherworker add to it. I'm also not too keen on having all that leather on the outside of the pack. It's difficult to completely waterproof leather, and when it gets wet, it would add to the weight of the pack. I really think heavy duty waxed canvas is a better choice. That's what my club used for canoeing, and some of those packs had to be at least 20 years old. The leather straps were always the first thing to break, not the canvas. Leather does not do well when it is repeatedly getting wet. Edit: I see Chuck and I are of the same mind re. the leather getting wet! Another afterthought: putting the shove on top of the pack is a bad idea. It would stick out too much and catch on bushes and rocks. It would have to go either on the side or the back of the pack. Since your bucket is wider than the shovel. I'd probably put it on the side, as having it on the back means it would be in the way when you needed to get something out of the pack. Edited July 10, 2022 by Sheilajeanne
CFM chuck123wapati Posted July 10, 2022 CFM Report Posted July 10, 2022 14 hours ago, Barron said: Yeah, I've seen a few that are some what close to what I need but the largest ones are just slightly small to fit what I need and don't have pockets, like giant hobo bags essentially. I, for the life of me, cannot find a large enough ruck sack made from leather. The largest are always cloth or cloth with canvas or leather bottoms. Really want something durable. Going to head to a place in Oregon later this week when I get out on the river and see what I can find at a leatherworker there. might look at these https://www.pcsoutdoors.com/ausablebrandtrappershardwoodveneerpackbasket20.aspx or this https://loadup.com/swiss-salt-pepper-rucksack-backpack-large.html or this https://www.armysurplusworld.com/new-us-gi-duffle-bag-genuine-us-military-surplus-duffel My claim was about a mile from any road with just a game trail, my setup worked well. I have the salt and pepper rucksack it is a tank and will hold up for years if you want i can put my pans and one of my small sluices and shoot in it and shoot some pics so you can tell if it would work. Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM chuck123wapati Posted July 10, 2022 CFM Report Posted July 10, 2022 14 hours ago, Barron said: Yeah, I've seen a few that are some what close to what I need but the largest ones are just slightly small to fit what I need and don't have pockets, like giant hobo bags essentially. I, for the life of me, cannot find a large enough ruck sack made from leather. The largest are always cloth or cloth with canvas or leather bottoms. Really want something durable. Going to head to a place in Oregon later this week when I get out on the river and see what I can find at a leatherworker there. here ya go it has my sluice and three pans it would be super easy for any good leather worker to add more pockets or just strap loops on the outside for more stuff, its an internal frame and is tougher than nails! Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members Sheilajeanne Posted July 10, 2022 Members Report Posted July 10, 2022 That looks promising! Yeah, easy to add extra pockets to that. Same goes for the wooden pack baskets.
MikeRock Posted July 10, 2022 Report Posted July 10, 2022 Barron and Sheilajeanne, THE canoeing pack was a big Bergen's Rucksack. Ideal for this prospecting equipment. Stick with waxed canvas with leather on the bottom and at some stress points. Plenty tough unless one is unnecessarily brutal to their stuff. We prospected all over eastern Wyoming, even where Chuck lives. Feldspars and quartz deposits, pegmatites. Flying and packing, horses and on foot, never wore out those packs. All leather is too heavy, just not ideal for either afoot or horseback. God bless
