Members oltoot Posted July 30, 2022 Members Report Posted July 30, 2022 were available in several sizes (wire guages of thickest part of the shaft) with #9 being the most commonly used. The large hole sideways on a rivit set tool is for forcing the washer down past the tapered end and onto the straight base. Quote
Members JShapiro Posted July 30, 2022 Author Members Report Posted July 30, 2022 Great, thanks y'all, I appreciate it. Quote
Members Wild Bill46 Posted August 4, 2022 Members Report Posted August 4, 2022 A Thank you to Bruce Johnson also a Thank you to Oltoot Quote
Members JShapiro Posted August 23, 2022 Author Members Report Posted August 23, 2022 OK, I'm finally getting around to ordering materials for this project. I need the rivets to go through approximately 1/2" of material (leather plus canvas). Should I get 3/4" or 1" post length? Thanks! Quote
Contributing Member fredk Posted August 23, 2022 Contributing Member Report Posted August 23, 2022 If you are sure its about 1/2" of material then 3/4" will do Quote Al speling misteaks aer all mi own werk..
Members jcuk Posted August 23, 2022 Members Report Posted August 23, 2022 I would go for a 1'' you can cut down to the size you need, you cant add any any length if they are to short. Hope this helps JCUK Quote
Members battlemunky Posted August 23, 2022 Members Report Posted August 23, 2022 19 minutes ago, jcuk said: I would go for a 1'' you can cut down to the size you need, you cant add any any length if they are to short. Hope this helps JCUK This^^^ It's rare that we get hardware that is one size fits all but with bit/burr rivets we can. Just get the long ones and trim them...you'll have to trim them anyhow so no need to stock more types than you need. Last time I bought them they were the same price regardless of length too. Quote
Members TomE Posted August 24, 2022 Members Report Posted August 24, 2022 Another idea is to use a shield and tab to attach the double bar buckle to the bag. It would be even stronger if you sandwich the canvas between 2 leather shields and sew through all 3 layers. This illustration is from Stohlman's Making Leather Cases v. 1. Quote
Members JShapiro Posted August 27, 2022 Author Members Report Posted August 27, 2022 (edited) On 8/23/2022 at 4:06 PM, battlemunky said: This^^^ It's rare that we get hardware that is one size fits all but with bit/burr rivets we can. Just get the long ones and trim them...you'll have to trim them anyhow so no need to stock more types than you need. Last time I bought them they were the same price regardless of length too. What is the best method for cutting them down? And if I cut them down, how much should I leave to hammer over? EDIT: Never mind, I found a good video on Buckleguy website. Thanks for your help, everybody! Edited August 27, 2022 by JShapiro Quote
Members battlemunky Posted August 27, 2022 Members Report Posted August 27, 2022 23 minutes ago, JShapiro said: What is the best method for cutting them down? And if I cut them down, how much should I leave to hammer over? EDIT: Never mind, I found a good video on Buckleguy website. Thanks for your help, everybody! It took me a little trial and error to get them where I like them. I took a piece of 3 oz leather and punched a hole in it to make a standoff, I set the rivet and then put the standoff over the stem and then use my side cut pliers flush with the standoff and it's where I like it. As long as the rivet is secure it should be fine so there is a little bit of feel to figuring out how much you like vs how much you don't. I found this to be the case anyhow. Too little is bad and too much is, well, too much...you have to find your inner Goldilocks. Quote
