Members ScottEnglish Posted August 3, 2022 Members Report Posted August 3, 2022 Hi. Are 4mm eyelets available without nicks? I make simple leather boots and use 4mm eyelets with nicks from Abbey England. Unfortunately, the nicked edges scuff the tongue of the boots. Thanks. Scott Quote
Members Grumpymann Posted August 3, 2022 Members Report Posted August 3, 2022 Have you tried grommets? A 2 piece eyelet like appliance. Quote
Members ScottEnglish Posted August 3, 2022 Author Members Report Posted August 3, 2022 Can you buy grommets with only a 4mm hole? I thought grommets are larger. I will have a look online. Thanks Grumpymann. Quote
Members ScottEnglish Posted August 3, 2022 Author Members Report Posted August 3, 2022 (edited) Having had a look on eBay, if the photos are accurate, it's possible to obtain 4mm internal diameter eyelets without nicks. I've also mailed Le Prevo to ask if they sell them. Scott Edited August 3, 2022 by ScottEnglish Quote
Contributing Member fredk Posted August 3, 2022 Contributing Member Report Posted August 3, 2022 Le Prevo is closed until August 15th The smallest sail eyelet is 5mm i/d The 4mm listed are not the ones you want http://www.leprevo.co.uk/eyelets.htm Quote Al speling misteaks aer all mi own werk..
Members ScottEnglish Posted August 3, 2022 Author Members Report Posted August 3, 2022 (edited) fredk: The no. 200 eyelets are nicked? Edited August 3, 2022 by ScottEnglish Quote
Contributing Member fredk Posted August 3, 2022 Contributing Member Report Posted August 3, 2022 34 minutes ago, ScottEnglish said: fredk: The no. 200 eyelets are nicked? Yes, look carefully at the size & colour example bottom left. You can just make out the nicks on the tube. Having seen that, look at the smallest gold and nickel ones and you can just make out the nicks http://www.leprevo.co.uk/photos/eyelet.html Quote Al speling misteaks aer all mi own werk..
Members mike02130 Posted August 3, 2022 Members Report Posted August 3, 2022 https://www.buckleguy.com/grommet-1-8-eyelet-0000-natural-brass-solid-brass-ll-100-sets-per-bag/ Quote @mike02130 Instagram
Members ScottEnglish Posted August 4, 2022 Author Members Report Posted August 4, 2022 fredk: Thanks. I wish I'd noticed that before mailing Le Prevo! mike02130: Thanks Mike. Those might work. Quote
