Members miker Posted October 11, 2022 Members Report Posted October 11, 2022 Hello everybody! Does anyone have any manual for this machine?I was told that it's a Global LP 943 (Minerva) machine Quote
Members Constabulary Posted October 11, 2022 Members Report Posted October 11, 2022 (edited) Global was probably the seller / distributor of this machine but not the manufacturer. They also sell used machines. I would assume a Minerva 72401, 72405 or something in between. EDIT: kinda like this one (scroll down): https://maszynyobuwnicze.wordpress.com/maszyny-szyjace-2/ Edited October 11, 2022 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
CowboyBob Posted October 12, 2022 Report Posted October 12, 2022 @miker It looks like this manual should work for you. CB8810_oper_man.pdf Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members miker Posted October 12, 2022 Author Members Report Posted October 12, 2022 9 minutes ago, CowboyBob said: @miker It looks like this manual should work for you. CB8810_oper_man.pdf 2.88 MB · 1 download Thank you!!! Quote
Members miker Posted October 15, 2022 Author Members Report Posted October 15, 2022 I am back again! In the picture, there is an Allen key on the machine. By turning this key you change the stitch length. Now as you use the machine, this knob is slowly turning to max size. Is there a way to tighten somehow the knob movement? The manual CowboyBob suggests have a different mechanism for stitch control Quote
Moderator Wizcrafts Posted October 15, 2022 Moderator Report Posted October 15, 2022 7 minutes ago, miker said: In the picture, there is an Allen key on the machine. By turning this key you change the stitch length. Now as you use the machine, this knob is slowly turning to max size. Is there a way to tighten somehow the knob movement? I'd first tighten the 3 screws on the round plate. If that makes no difference, or they're already tight, remove them and see if there is another screw under the cover to lock down the adjuster screw. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members miker Posted October 15, 2022 Author Members Report Posted October 15, 2022 15 minutes ago, Wizcrafts said: I'd first tighten the 3 screws on the round plate. If that makes no difference, or they're already tight, remove them and see if there is another screw under the cover to lock down the adjuster screw. The 3 screws are already tightened. Quote
Members Constabulary Posted October 15, 2022 Members Report Posted October 15, 2022 (edited) I would tilt back the machine and check what the allen key is doing... EDIT: You can download parts lists here. Maybe they help you to figure the function. https://rexel-com-pl.translate.goog/content/33-katalogi-minerva?_x_tr_sl=auto&_x_tr_tl=de&_x_tr_hl=de&_x_tr_pto=wapp Edited October 15, 2022 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members miker Posted October 15, 2022 Author Members Report Posted October 15, 2022 9 minutes ago, Constabulary said: I would tilt back the machine and check what the allen key is doing... the problem is that i don't have access to the machine! Is in another place. I am helping a friend! Quote
Members Constabulary Posted October 15, 2022 Members Report Posted October 15, 2022 (edited) see above post, I just edited it. Maybe the parts lists help to figure the function. Or maybe the REXEL Co. can provide a manual. I´d check with them. This is from a list I downloaded Edited October 15, 2022 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
